Drive PID works. Turn PID does not work
This is my code for drive pid:
void driveTo(double distance_in, double time_limit_msec, bool exit, double max_output) {
  // Store initial encoder values
  double start_left = getLeftRotationDegree(), start_right = getRightRotationDegree();
  stopChassis(vex::brakeType::coast);
  is_turning = true;
  double threshold = 0.5;
  int drive_direction = distance_in > 0 ? 1 : -1;
  double max_slew_fwd = drive_direction > 0 ? max_slew_accel_fwd : max_slew_decel_rev;
  double max_slew_rev = drive_direction > 0 ? max_slew_decel_fwd : max_slew_accel_rev;
  bool min_speed = false;
  if(!exit) {
    // Adjust slew rates and min speed for chaining
    if(!dir_change_start && dir_change_end) {
      max_slew_fwd = drive_direction > 0 ? 24 : max_slew_decel_rev;
      max_slew_rev = drive_direction > 0 ? max_slew_decel_fwd : 24;
    if(dir_change_start && !dir_change_end) {
      max_slew_fwd = drive_direction > 0 ? max_slew_accel_fwd : 24;
      max_slew_rev = drive_direction > 0 ? 24 : max_slew_accel_rev;
      min_speed = true;
    if(!dir_change_start && !dir_change_end) {
      max_slew_fwd = 24;
      max_slew_rev = 24;
      min_speed = true;
This is my code for Turn PID:
void turnToAngle(double turn_angle, double time_limit_msec, bool exit, double max_output) {
  // Prepare for turn
  is_turning = true;
  double threshold = 1;
  PID pid = PID(turn_kp, turn_ki, turn_kd);
  // Normalize and set PID target
  turn_angle = normalizeTarget(turn_angle);
  pid.setTarget(turn_angle);
  pid.setIntegralMax(0);
  pid.setIntegralRange(3);
  pid.setSmallBigErrorTolerance(threshold, threshold * 3);
  pid.setSmallBigErrorDuration(50, 250);
  pid.setDerivativeTolerance(threshold * 4.5);
  // Draw baseline for visualization
  double draw_amplifier = 230 / fabs(turn_angle);
  Brain.Screen.clearScreen(black);
  Brain.Screen.setPenColor(green);
  Brain.Screen.drawLine(0, fabs(turn_angle) * draw_amplifier, 600, fabs(turn_angle) * draw_amplifier);
  Brain.Screen.setPenColor(red);
  // PID loop for turning
  double start_time = Brain.timer(msec);
  double output;
  double current_heading = getInertialHeading();
  double previous_heading = 0;
  int index = 1;
  if(exit == false && correct_angle < turn_angle) {
    // Turn right without stopping at end
    while (getInertialHeading() < turn_angle && Brain.timer(msec) - start_time <= time_limit_msec) {
      output = pid.update(current_heading); // PID update for heading
      // Draw heading trace
      Brain.Screen.drawLine(index * 3, fabs(previous_heading) * draw_amplifier, (index + 1) * 3, fabs(current_heading * draw_amplifier));
      index++;
      previous_heading = current_heading;
      // Clamp output
      if(output < min_output) output = min_output;
      if(output > max_output) output = max_output;
      else if(output < -max_output) output = -max_output;
      driveChassis(output, -output);
      wait(10, msec);
  } else if(exit == false && correct_angle > turn_angle) {
    // Turn left without stopping at end
    while (getInertialHeading() > turn_angle && Brain.timer(msec) - start_time <= time_limit_msec) {
      index++;
      driveChassis(-output, output);
      wait(10, msec);
  } else {
    // Standard PID turn
    while (!pid.targetArrived() && Brain.timer(msec) - start_time <= time_limit_msec) {
      index++;
      wait(10, msec);
  if(exit) {
    stopChassis(vex::hold);
  correct_angle = turn_angle;
  is_turning = false;
I found that even if I change kp, ki, kd for turn PID, it changes nothing in the robot’s turning. Robot keeps going back and forth, oscillating (even if the kp is low, ki and kd is 0..). However, I don’t think that the code is the problem since I downloaded from github. What do you guys think?
edit: code tags added by mods, please remember to use them.
Is it possible to provide a source to the GitHub? I see unique functions to the PID class that I am unsure what they are doing
