I set up a dual-motor drivetrain, I set up tank treads on the controller. When I tell the motor to go forward it ends up going backward, and when I go backwards it goes backwards but cuts out for a split second.
Could you share your drivetrain code?
You may have to reverse the motors because you connected them upside down. But I agree with @Sarknought , code will help solve the issue.
There isn’t any code, the drive-train was set up through the TextCode UI as well as it being controlled by the Controllers
I’m having the same issue. Did you find a reason/solution?
Er, the original post was from two years ago. Start a new topic.
