My team is struggling with shaft collars. Last year it wasn’t and issue, but this year it is making our drivetrain unstable and they are causing the gear allignment to be uneven. We screw the shaft lock screws into the axel for the motors, and no matter how hard we try, there is always some space in between that causes the axel and gear to be loose. I researched other Forums, and no one else has talked about this topic. Does anyone know how I can fix this?
Sometimes if the axles you are using are old and worn down, they don’t have friction against the screw anymore causing it to slide. Try using a new axle and see if that changes things.
I’d say if they “all” are doing this… I’m suspecting your screwdrivers are “bad”, meaning partially stripped or worn out.
#1 reason drivers are worn is using them off angle & letting them slip.
Remove the axle and see how far into the collar the set screw will go. It should screw fully into the collar and bottom out onto the far side of the hole.
If clearance allow, you can swap the set screw for a regular screw. This will allow the T15 screwdriver to be used. The head is larger so you can apply more torque.
