Drivetrain self-destructing
My drivetrain is in the shape of a triangle(taking inspiration from Ben Lipper), but instead of using all that fancy stuff, I settled on a standard drivetrain using an A-frame, or a triangle shaped field element, as VEX calls it. The shaft that turns the main gear(I am driving a 24 by 16 tooth) keeps falling off, making the main gear fall onto the ground. My team is made up of middle schoolers, and we don’t have a pneumatics kit-we have to earn it. It would be great if someone like @Quail_Pepper or @5020_Offical could help me out. I might be able to send pics in a couple of days, but just first bounce some ideas around!
Why did you make 2 threads? It was only necessary to do one. As for your drive, pictures are necessary to fully understand and I am not an expert on drive trains but I will try to help. If it is the shaft that is connected to the motor and its falling out of the motor, I am fairly certain there is a piece to help with that (I’m not in IQ). If it is not the shaft connected to the motor then it shouldn’t fall out as long as you use shaft collars.
Will help a lot.
Have you tried adding anything to attempt to block movement of the shaft?(rubber shaft collars, beams, etc). What type of shaft are you using?(Motor shafts, Capped shafts, etc)
sorry im new to the thread so I didn’t know where to see my pending posts :sweat_smile:
