Drivetrain tips
Hey guys, I am just curious, What type of drivetrain gear ratios, gear cartridges, and wheel size would be the best? just curious
Here is a spreadsheet listing all ratios and their speeds and any problems with them Drivetrain Speeds
As for which you should use it depends on driver experience and your strategy but most robots use anywhere from 333RPM on 3.25 to 600RPM on 2.75 and a good middle speed for a newer team would be 360RPM (36:60 blue motors) on 3.25in wheels.
For new drivers I recommend 36:60 gear ratio on 3.25 in wheels, it is good for any sort of barrier cross game, as the 36 teeth gears are basically hidden in the drivetrain. For better drivers 36:48 is 450rpm, which is pretty fast and the upper limit of 3.25 in wheels. All of these use blue motor cartridges. And
for barrier cross games like this one and spin up, I recommend the 10b tech of intregating the sleds and the motor stacks, not to use too much metal. Finally I personally like driving all omni for better turning while already moving
It really depends on your driver and their preferences. Generally, the viable range for drivetrain speeds is in-between 52 (ish) inches per second to around 80 inches per second. Generally, for teams that are just starting out, I would place the limit on drivetrain speed at around 65 inches per second, anything faster can be way too hard to control.
Using blue motors is also better than using red or green motors, since you can gear up using blue motors. For example, look at any drivetrain using green motors here: Catalogue of Drive Gearings Notice how the bigger gears are on the outsides of the wheels. For some forms of elevation, using green motors would cause a lot of issues because of this. If you look at any drivetrain gearing that uses blue motors, the bigger gears are hidden, making elevation tasks easier, and sometimes actually possible. Not to mention, gearings that use Green motors are also more bulky, which can be a deal breaker for some drivetrain sizes. Using green motors for a drivetrain is okay, but avoid it if you can.
In terms of wheels, you can use any of them and have a good time. However, if you can avoid 4 inch wheels, do that. It can limit wheel placements, your robot drivebase would be higher off the ground, (a deal breaker for some teams as well), and it limits you gearing options a little too much in my opinion. 4 inch wheels can be used well, but you have better options if you can make use of them. In terms of what kind of wheels to actually use (Omni wheels or a mix of traction wheels and Omni wheels), it depends on your drivers preferences and what wheels you have. Generally, if you want traction wheels, put them somewhere in the middle of your drivetrain (whether it is directly in the middle or offset in the middle). And, please, don’t make the mistake of making your drivetrain all traction wheels.
Drivetrain size varies… a lot. For almost any team, I would say any drivebase size from 27 holes by 27 holes (13.5 in by 13.5 in) to 32 holes by 32 holes (16 in by 16 in). Anything smaller than 25 hole by 25 holes or anything bigger than 33 by 33 holes may be too limiting. This will heavily depend on your gearing and wheels, so figure out what gearing you want before you figure out the size of your drivebase.
Sorry I said a lot of words, but there are a lot of variables to consider for drivetrains. Good luck out there.
That very much depends on the weight and size of the robot which, in turn, depends on the weight and size of the game objects that you need to carry and manipulate.
Depending on the game and strategy, some teams had success with super light and fast robots, while others build slow fortresses on wheels and made it to the top as well.
Finally, your choice may depend on your driver preference over which speed fits best to their driving style. Some drivers like to zip around the field messing with and stealing game objects from both of the opposing teams. While other drivers may prefer to methodically work the scoring in the isolated corner of the field, if game mechanics permits.
There is nothing wrong on settling on the “middle of the road” perfectly average design, but you should definitely try to build both extremes of the slow and fast chassis to learn their pros and cons.
350 6 motor blue with 3.25 wheels is considered the best most of the time
