Elevator Project
task main()
while ( 1 == 1)
if(SensorValue(dgtl2==1))
startMotor (Elevator , 25);
wait(6.1);
stopMotor (Elevator);
if(SensorValue(dgtl1==1))
wait(12.2);
stopMotor(Elevator);
if(SensorValue(dgtl4==1))
startMotor (Elevator , -25);
wait(6.4);
if(SensorValue(dgtl3==1))
wait (6.1);
if(SensorValue(dgtl6==1))
wait(14.2);
if(SensorValue(dgtl5==1))
wait (6.1);
I am doing the Elevator project for POE. Whenever I start the program the motor starts automatically, I am just confused as to how to make each button work independently.
Try using an else statement and see if it fixes the problem. That will create a base state of resting. It could also be as simple as you need to cycle your cortex power completely off and on or robotc itself.
Add in an
else
motor (Elevator) =0;
You shouldn’t have the extra { between the if and the while. Brackets should only begin and end each of your conditional statements (if&while in this case), not go around them…
#fixformattingisyourfriend
For
‘if(SensorValue(dgtl2==1))’,
I think it should say: if(SensorValue[dgtl2]==1)
Is that even ROBOTC?
There is so many errors that I don’t really think it would be…
I think it’s the Natural Language version.
I could try to make a sample program for you :slight_smile:
And yes, Natural Language is ROBOTC…
Just tell me all the ports and I would write one for you, and what button you want to press to activate that motor…
@DeadMagicSocial Here’s my finished product, you should’ve added ‘else if’ and ‘else’. Also including to stop the motors when nothing is pressed… It should work (Plus you had too many ‘}’ in the code);
task main() //Start task
while ( 1 == 1) //While Remote is connected
if(SensorValue[dgtl2]==1) //While Dgtl2 is active
motor[Elevator]=25; //Motor Elevator at 25 power
wait1000msec(6.1); //Wait 6.1 seconds
motor[Elevator]=0; //Motor elevator at 0 power
else if(SensorValue[dgtl1]==1) //While Dgtl1 is active
wait1000msec(12.2); //Wait 12.2 seconds
motor[Elevator]=0; //Motor Elevator at 0 power
else if(SensorValue[dgtl4]==1) //While Dgtl4 is active
motor[Elevator]=-25; //Motor Elevator at -25 power
wait1000msec(6.4); //Wait 6.4 seconds
else if(SensorValue[dgtl3]==1) //While Dgtl3 is active
wait1000msec(6.1); //Wait 6.1 Seconds
else if(SensorValue[dgtl6]==1) //While Dgtl6 is active
wait1000msec(14.2); //Wait 14.2 seconds
motor[Elevator]=0; Motor Elevator at 0 power
else if(SensorValue[dgtl5]==1) //While Dgtl5 is active
else
I think I’d do it this way (your pick, though).
task main()
while (true)
if(SensorValue[dgtl2] || SensorValue[dgtl3])
motor[Elevator]=25;
wait1Msec(6100);
motor[Elevator]=0;
else if(SensorValue[dgtl1])
motor[Elevator]=25;
wait1Msec(12200);
motor[Elevator]=0;
else if(SensorValue[dgtl4])
motor[Elevator] = -25;
wait1Msec(6400); //Is this supposed to be 6.4 secs?
motor[Elevator]=0;
else if(SensorValue[dgtl6])
wait1Msec(14200);
motor[Elevator]=0;
else if(SensorValue[dgtl5])
wait1Msec(6100);
motor[Elevator]=0;
else motor[Elevator] = 0;
Also, there might be a thing about the ports evaluating to 1 if not pressed and 0 if pressed, I’m not sure. Sorry about the lack of comments, but Vex Forum’s limited line length on iPhone makes them come out weirdly.
I didn’t know you could do that code and /code thing! Thanks!
