Elipse turning with a gyro sensor
I was working on sensor programming for team 785 using the gyro sensor but i ran into a road block when trying to do ellipses my issue is once i turn one direction i cant turn back to the original direction there aren’t any errors in the code i just don’t know what i have to change in order to go in reverse after i already made a turn
#include "robot-config.h"
void preauton()
  vex::task::sleep(300);
  Gyro.startCalibration();
  while(Gyro.isCalibrating())
    vex::task::sleep(1);
void autodrive(int speed)
    leftMotor.spin(vex::directionType::fwd,speed,vex::velocityUnits::rpm);
    rightMotor.spin(vex::directionType::fwd,speed,vex::velocityUnits::rpm);
void autoturn(int speed)
    rightMotor.spin(vex::directionType::fwd,-speed,vex::velocityUnits::rpm);
void autoelip(int speed, int speed2)
    leftMotor.spin(vex::directionType::fwd,speed2,vex::velocityUnits::rpm);
void autoturntime(int speed, int mSec)
 autoturn(speed);
 vex::task::sleep(1000);
 autodrive(0);
void elip(int speed, int speed2, int deg)
    Gyro.isCalibrating();
    while( fabs(Gyro.value(vex::rotationUnits::deg)) < deg*.6)
autoelip(speed, speed2);
while( fabs(Gyro.value(vex::rotationUnits::deg)) < deg*.8)
autoelip(speed*.8, speed2*.8);
while( fabs(Gyro.value(vex::rotationUnits::deg)) < deg)
autoelip(speed*.6, speed2*.6);
autoturntime(-speed/2, 50);
int main ()
	preauton();
	if (Gyro.value(vex::rotationUnits::deg)<60)
    elip(50, -100, 60);
preauton();
	if (Gyro.value(vex::rotationUnits::deg)>1)
    elip(100, -50, 1);
the robot config is
vex::brain Brain;
vex::motor rightMotor = vex::motor(vex::PORT1);
vex::motor leftMotor = vex::motor(vex::PORT2,false);
vex::gyro Gyro = vex::gyro(Brain.ThreeWirePort.A);
anything helps thank you
nvm i fixed it i just needed to put the destination degrees from 1 to 60 because preauton sets the sensor values back to zero and added a wait time so when the sensor values are being reset it has a little time to calibrate and reset instead of instantly going right after
You don’t have to recalibrate the Gyro before every rotation.
Please, try to avoid using fabs(Gyro.value()) function.
For PID starting from any heading you can calculate error=Gyro.value(vex::rotationUnits::deg)-targetDeg
Then turn only as long as fabs(error)>someThreshold.
You may also refer to this example: Drivetrain gyro turning - #3 by jpearman
