Error 038214C
i dont know what is wrong with the code everythign fails when im coding pneumatics
competition Competition;
vex::motor  RightFrntmotor = vex::motor( vex::PORT1,true);
vex::motor  RightBckmotor = vex::motor( vex::PORT2,true);
vex::motor  LeftFrntmotor= vex::motor( vex::PORT3,true);
vex::motor  LeftBckmotor= vex::motor( vex::PORT4,true);
vex::motor  CallOfDuty= vex::motor( vex::PORT5,true);
vex::motor  CallOfDuty2= vex::motor( vex::PORT6,true);
vex::controller Controller1= vex::controller();
vex::digital_out dig1 = digital_out( Brain.ThreeWirePort.H );
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the V5 has been powered on and        */
/*  not every time that the robot is disabled.                               */
void pre_auton(void) {
  vexcodeInit();
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
void autonomous(void) {
//Forward
RightFrntmotor.startRotateFor(vex::directionType::fwd, 1000, vex::rotationUnits::deg);
RightBckmotor.startRotateFor(vex::directionType::fwd, 1000, vex::rotationUnits::deg);
LeftFrntmotor.startRotateFor(vex::directionType::fwd, 1000, vex::rotationUnits::deg);
LeftBckmotor.rotateFor(vex::directionType::fwd, 1000, vex::rotationUnits::deg);//starter
//Right(swing)
LeftFrntmotor.startRotateFor(vex::directionType::fwd, 900, vex::rotationUnits::deg);
LeftBckmotor.rotateFor(vex::directionType::fwd, 900, vex::rotationUnits::deg);//starter
//Left(swing)
RightFrntmotor.startRotateFor(vex::directionType::fwd, 900, vex::rotationUnits::deg);
RightBckmotor.rotateFor(vex::directionType::fwd, 900, vex::rotationUnits::deg);//starter
//right(close)
LeftBckmotor.startRotateFor(vex::directionType::fwd, 900, vex::rotationUnits::deg);
RightFrntmotor.startRotateFor(vex::directionType::rev, 900, vex::rotationUnits::deg);
RightBckmotor.rotateFor(vex::directionType::rev, 900, vex::rotationUnits::deg);//starter
//left(close)
RightBckmotor.startRotateFor(vex::directionType::rev, 900, vex::rotationUnits::deg);
LeftBckmotor.rotateFor(vex::directionType::fwd, 900, vex::rotationUnits::deg); //starter
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
void usercontrol(void) {
  while (1) {
    RightFrntmotor.spin(vex::directionType::rev, (Controller1.Axis1.value() + Controller1.Axis2.value()), vex::velocityUnits::pct);
    RightBckmotor.spin(vex::directionType::rev, (Controller1.Axis1.value() + Controller1.Axis2.value()), vex::velocityUnits::pct);
    LeftFrntmotor.spin(vex::directionType::fwd, (Controller1.Axis1.value() - Controller1.Axis2.value()), vex::velocityUnits::pct);
    LeftBckmotor.spin(vex::directionType::fwd,   (Controller1.Axis1.value() -  Controller1.Axis2.value()), vex::velocityUnits::pct);
    CallOfDuty.spin(vex::directionType::fwd, -Controller1.ButtonR2.pressing()*100, vex::velocityUnits::pct);
    CallOfDuty2.spin(vex::directionType::fwd, -Controller1.ButtonR2.pressing()*100, vex::velocityUnits::pct);
    // Insert user code here. This is where you use the joystick values to
    // update your motors, etc.
     RightFrntmotor.spin(vex::directionType::rev, (Controller1.Axis2.value() + Controller1.Axis1.value()), vex::velocityUnits::pct);
    RightBckmotor.spin(vex::directionType::rev,  (Controller1.Axis2.value() + Controller1.Axis1.value()), vex::velocityUnits::pct);
    LeftFrntmotor.spin(vex::directionType::fwd, (Controller1.Axis2.value() - Controller1.Axis1.value()), vex::velocityUnits::pct);
    LeftBckmotor.spin(vex::directionType::fwd, (Controller1.Axis2.value() - Controller1.Axis1.value()), vex::velocityUnits::pct);
    wait(8, msec); // Sleep the task for a short amount of time to
                    // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
   while(1) {
  int count = 1;
   if( Controller1.ButtonL1.pressing() ) {
      dig1.set( true );
    else{
      dig1.set( false );
    this_thread::sleep_for(10);
  // Set up callbacks for autonomous and driver control periods.
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
edit: code tags added by mods
Firstly, welcome to the forums. Can you tell me what the behavior is when it fails? Also please add code tags to make your code more readable.
The code builds for me without any issues. Could you please be more specific about what the issue is? Are you able to even download the code? Is it able to compile? Or does it just not have the intended functionality when run?
Properly Formatted Code
#include "vex.h"
using namespace vex;
/* Pre-Autonomous Functions /
/ You may want to perform some actions before the competition starts. /
/ Do them in the following function. You must return from this function /
/ or the autonomous and usercontrol tasks will not be started. This /
/ function is only called once after the V5 has been powered on and /
/ not every time that the robot is disabled. /
  vexcodeInit();
  // Example: clearing encoders, setting servo positions, …
/ Autonomous Task /
/ This task is used to control your robot during the autonomous phase of /
/ a VEX Competition. /
/ You must modify the code to add your own robot specific commands here. /
  //Forward
  //Right(swing)
  //Left(swing)
  //right(close)
  //left(close)
/ User Control Task /
/ This task is used to control your robot during the user control phase of /
  while (1) {
  wait(8, msec); // Sleep the task for a short amount of time to prevent wasted resources.
int main() {
  while(1) {
    int count = 1;
      dig1.set( true );
    else{
      dig1.set( false );
  pre_auton();
  while (true) {
    wait(100, msec);
probably this,
see this and other topics concerning memory permission errors.
another topic discussing this issue.
