EXP field walls
This is an EXP question, but there doesn’t seem to be an EXP-specific forum.
Anyhow, the field walls for the VEX EXP system have slots in in the top. What are these intended to be used for? Are there any CAD models for these parts? The store doesn’t seem to have CAD models for the wall sections. Seems like you could add some wall extensions (maybe some AprilTag markers).
This post is likely going to be unanswered, but who knows¯_(ツ)_/¯
These serve no defined user-intended purpose, and exist solely as a design-necessitated feature due to the manufacturing method of the part, injection molding.
In Injection Molding, it is required to keep a constant (or as close as possible to constant) wall thickness of plastic in order for the part to be able to be made without defects.
The tab features on the Education Field Wall are more of a lower profile (this is done for easier packaging and storage), so they sit “below” the main portion of the wall. This is a stark contrast to the IQ Wall features, that exist on a flange, separate from the taller boss that creates the wall feature.
In order to create this feature, there needs to be a Mold Slide (pink box as shown in picture) to create a “shutoff” wall so that feature can be formed. This means the “negative” of the part, or the part that would fit “inside” of the outer geometry of the wall, can only go so far into the part at the location of that feature. If this shutoff wall did not exist, the tab feature would have to exist for the entire height of the wall.
Because it can only go up to about where that red line is on the part, it would create a “solid” Thick Region of plastic in the area above the red line. This is a BIG no-no in injection molding, as it would almost guarantee part failure in the mold. A large thick region like that means the hot, molten plastic would not be able to flow through the mold to fill all regions of the part properly, because this thick region creates a serious pressure void, preventing consistent flow.
In order to prevent this thick region, we just add a feature from the “cavity” side of the mold (Dark Blue part) to create a “pocket” in the part to keep wall thickness more consistent.
Here is a section view of the part, and I traced all of the walls with red. Notice how all areas traced in red are approximately the same thickness. This makes for a well-designed injection molded part.
If instead, the part looked more like this (assume the red area shaded is solid plastic, without these slots)
The part would have what we call Sink and Short Shotting in this area, which would look like small dents, or completely missing areas of the part, if not worse.
Design for injection molding is really cool, really fun, and I enjoy geeking out on it, so thanks for the excuse! I recommend watching videos on YouTube or doing your own research on the topic if this is interesting to you… there are people out there that can explain it far better than I can!
TL;DR, its a necessary design feature for the way the part is manufactured, and not intended to be a user-facing feature.
Though there is nothing stopping you from designing something to fit into that slot for use in the classroom. April Tag markers that slot in there would be a neat idea!
Thanks for the thorough reply!
Are the CAD models for those wall sections available? I did not see them as available on the Vex-Store.
I’ll talk to the web team about getting it added, but here’s a STEP file for now:
269-7377 VEX Education Field Wall.STEP (662.0 KB)
