HI, good afternon, I need ideas to create a powertrain with 6 blue cartridge motors…
I have gears of 84, 72 and 36
Hi! Try using the search bar. This topic is great.
Adding on to what the user above said, the forum is generally not a place where people will give you ideas. Use the search bar or look on YouTube to find inspiration for your drivetrain. Good luck!
ROBOTC Tech Support means you are using a cortex brain (that has no longer been sold for quite some time) with ROBOTC programming language.
Robot-Mesh has also been discontinued for quite some time as well.
