Help on the V5 Air Pressure Regulator. [ASAP]
Hi guys,
I recently bought the new V5 pneumatics kit. I don’t really understand the purpose of the air pressure regulator. I’m working on a Mogo mech, and I don’t know if it is really necessary. I also need the piston’s maximum power to tilt it. I am using one tank. One small piston only for the mogo clamp. Can someone help ASAP?
If you want the maximum pressure then no need for the regulator. An example for use of the regulator would be if you only need like 65 psi per clamp, so if you regulated the air it would only use 65 psi per clamp theoretically giving you more clamps at a consistent pressure.
not necessary for just 1 goal clamp. if you just need something that works, ignore it for now.
