I have been hitting a brick wall in terms of tuning the angular PID in LemLib. The graph in the explanation on the docs is easy to understand, but I can’t seem to get it right.
Trying with my robot, I have been unable to find any Kp value that does this. I found to 3d the value where the robot has just enough power to turn, not stall. When it gets to the target, it starts a constant oscillation about 5 degrees in each direction forever.
Increasing the Kp, the same occurs simply faster, with a larger oscillation at the target.
At first, I thought I could solve this with some Kd, but I tried at a range of values, between just enough power and reasonable turn speed. But no luck. Any Kd was either too low or just made the robot spin in circles.
Has anybody encountered this before?
Maybe the Imu is a little too slow or imprecise for the final few degrees at the end. (But no one else seems to have issues with LemLib)
I’m running 6m blue 360rpm on 3.25, and the drivetrain has very minimal backlash. (Don’t think the problem is physical)
If it’s doing that, you might have reduced friction to the point where it’s extremely difficult to find that point. If that is the case, increase kD until the robot undershoots the turn by like 1-2 degrees.
Make integral (the result multiplied by kI) only activate if the robot is within like ±10 degrees from the target
You can add something where integral (or totalerror) resets to 0 if the robot passes 0 (if previous error is positive and current error is negative, or if previous error is negative and current error is positive, reset totalerror to 0).
After, tune kI such that the robot can snap to the desired target.
This is very similar to what I was told by a member of BNS when I talked to then years ago, when I saw how snappy their auton was.
In my experience, PID tuning is very finicky. However, my team switched from LemLib to MikLib this season, and I have spent half as much time tuning PIDs as I have in the past. Our whole organization loves MikLib and would definitely recommend it.
As far as the actual tuning is concerned, generally, the steps are to tune kP, then kD, then kI, but I am no expert on this and typically require other people’s input when tuning.
I setup everything with MikLib and still had the same issue. It’s way simpler to edit core code in Miklib so I added~some debug code to the pid compute function.
What I found was during the turn_to_angle(20); the error was increaseing as it turned right. After changing the Inertia scale to -360 the error was working as expected and the ocilations and randomness went away.
I can’t be sure, but the very similar symptoms makes me think Lemlib is having the same issue. I can definitely use MikLib if needed. MikLib looks amazing, I just like to mess around with LVGL lots. I’ll do some experementing with Lemlib to see if I can replicate the same fix.
Thank you to all the people who decided to reply
Might post an update when I’ve tested with Lemlib
I was able to make a custom imu with a scaler of -1. Looking at chassis.getPos().theta shows the right is now positive. (How did I not notice the backwards angles) And PID issues are gone.
Hindsight 2020, this is most likely to do with my upside down mounted IMU. I didn’t think of it as I haven’t had issues with upside down imu before. Maybe the get heading command aligns with gravity when calibrated? While rotation doesn’t?
