So i have a holonomic chassis and it has high speed motor. They are in Cortex port 2,3,4, and 5. When ever i practice for like 45 sec the robot has a twitches when ever i try to move it again. What is the problem here? There is no friction happening, nothing touching the floor… Do i have to change the motors to high strength?
After you test do the motors get really warm cause if they do the heat sensors are tripped. It might do this because its to much weight for the motors to move.
I would check to see that the rollers on the omniwheels aren’t rubbing against the metal. I would also try a different cortex. You’re probably tripping the PTCs in the motors or the cortex. Does it happen if the wheels aren’t touching the ground for those 45 secs?
All of those ports are on the same cortex breaker (1-5). I bet that is what you are tripping. Does anything else go out when the drive goes out?
If this is the problem, I would recommend putting 2 drive motors on breaker 1-5 and 2 on 6-10.
If that doesn’t solve it, it may be static or something else.
You can just unplug the cable because that was what I did and it fixed it. For the drive you should switch to quadrature encoders when you have the time.
hmm… maybe you should try removing the IME. Have you also tried lubricating the gears and axles. Have you also checked to see if you have any bent axles?
What (I’m pretty sure) @Cyber brains meant was this: The cortex has two separate fuses which prevent motors from drawing too much current. Ports 1-5 share one fuse, and ports 6-10 share another fuse. Because you are connecting all four drive motors to the same bank of ports on the cortex (i.e., to the same fuse), it seems likely from the behavior you described that the total current draw from all four drive motors exceeds the limit of the fuse (if I remember correctly, about 4 amps). To solve this problem, distribute the motors evenly between the two fuses. For example, you might connect the two of the drive motors to ports 2 and 3, and the other two motors to ports 8 and 9.
So try balancing the motors between the two fuses on the cortex and see if that solves your problem.
So the best I could tell you for the time being is to switch to torque gears with half of the motors plugged in to the power expander and half to the cortex.
One last thing you do before that though is to send a picture on here so we can see if there are any other problems we can see.
