How do I get more speed out of a blue cartridge motor for flywheel?
Also, feel free to ask coding questions, but I am only experienced on some block coding, so don’t expect me to know everything.
A quick heads up as well: The middle gear seems to be in place because the motor output shaft would touch the flywheel if it were too long, so be prepared to find a shorter axle or cut an axle if you don’t have one the right length
i have no idea if others have said this already but it looks like you don’t have enough torgue to spin it at the speed you want, it also looks like your gear ratio is a little larger than nessicary. people have said to look at the 3600 direct motor but if you would like look at adding a 2nd motor just to add more torgue and to help it spin up faster.
If someone is buying flex wheels, now may be the time to buy them. Me and a friend recently bought a good amount and we have gotten one of the types we were told was on hold already, within about 5 days. They are relatively expensive so be prepared to spend about $90 for enough for an intake, roller spinner, and flywheel.
This is true, my coach just bought a ton for the rest of the teams, and we are using our own. He back ordered them, so they will arrive around December.
Yeah we have a couple on order for our flywheel
