How do you attach an electric ryobi pump to the Schrader valve on the pneumatics cylinder?
I have a ryobi inflator pump, and I am trying to inflate the piston cylinder with pressure, but every time I try, it goes so quick, and then shuts off. Almost as if it is measuring inside and pumping into the valve, but from there it goes nowhere. I just got this, and I want to make sure this works. I am pretty sure this would work, but I don’t know how I can get air inside.
URL for pump: https://www.homedepot.com/p/RYOBI-ONE-18V-Cordless-High-Pressure-Inflator-Kit-with-2-0-Ah-Battery-and-Charger-PCL001K1/326781687
You should make sure all tubing it in correct not leaking. Them plug in pump into the golden and if you do shut the shut off valve
For this pump you can set the max pressure for the pump to go to, so make sure to use the (+) (and (-)) buttons to increase that max pressure (top number) to 100 psi
We use the exact same RYOBI pump, and can confirm that it does work.
Please tell me how you’re able to use it. I sincerely need help. Is it a different adapter?
What does your set up look like now? Sorry that no one answered you sooner
Can I text you on instagram or somehow? To get faster information. I currently have the tank hooked up to a valve that when you turn, after it fills up you turn it and it leaks the compressor air, more like a shutoff valve. And then following is a tube connected to the type of valve you’d see on a car.
I’m just putting the overhead onto the valve, securing it tight, and and then close that valve on the pump, then I pump.
If you contact VEX Customer Support about this issue, they’ll be able to help you.
Email: [email protected]
