How To Implement Multiple Motor To One Joystick
I wrote a program to implement a 6 motor drivetrain into 2 joysticks. The left joystick controls the left side motors and the right joystick controls the right side motors. But I run into the issue of my code not compiling even after looking at several forums. Can someone help me out with this?
// Robot Configuration:
// [Name]               [Type]        [Port(s)]
// Controller1          controller
// LeftForwardMotor     motor         1
// LeftMiddleMotor      motor         2
// LeftRearMotor        motor         3
// RightFrontMotor      motor         4
// RightMiddleMotor     motor         5
// RightRearMotor       motor         6
#include "vex.h"
using namespace vex;
int main() {
  vexcodeInit();
  const int wheelTravel = 320;
  const int trackWidth = 320;
  const int wheelBase = 130;
  motor_group leftMotors(LeftForwardMotor, LeftMiddleMotor, LeftRearMotor);
  motor_group rightMotors(RightFrontMotor, RightMiddleMotor, RightRearMotor);
  drivetrain myDrivetrain(leftMotors, rightMotors, wheelTravel, trackWidth, wheelBase, mm);
  motor[leftMotors] = vexRT[Controller1.Axis3];
  motor[rightMotors] = vexRT [Controller1.Axis2]
I believe you are mixing the ROBOTC language with VEXCode
#include "vex.h"
int main() {
  vexcodeInit();
while(1){
  leftMotors.spin(fwd, Controller1.Axis3.Value(), percent);
rightMotors.spin(fwd, Controller1.Axis2.Value(), percent);
vex::task:sleep(10):
I think this should work, but I’m not quite sure. Haven’t used VEXCode’s motor groups before
Is this not how you configure motors and motor groups?
Here is another option using .setVelocity
    int leftSpeed;
    int rightSpeed;
    while (true) {
        //Tank control
        leftSpeed  = Controller1.Axis3.position();
        rightSpeed = Controller1.Axis2.position();
        LeftDriveGroup.setVelocity(leftSpeed, percent);
        RightDriveGroup.setVelocity(rightSpeed, percent);
        wait(20, msec);
Can you elaborate a bit more on this? Where are you establishing the 6 motors and where is the ‘LeftDriveGroup’ and ‘RightDriveGroup’ variable coming from?
I made the assumption that you had already had the motor groups configured. Below is an example that should help in VexCode Pro.
