How do you score in VEX VR? I can’t get the arm to go down to slam dunk the ring. Any help is appreciated.
You need to use the pusher_motor, which pushes the rings off the arm.
Here is a small section of code that will score one ring on the red stake:
def main():
drivetrain.turn_for(LEFT, 90, DEGREES)
drivetrain.drive_for(FORWARD, 500, MM)
arm_motor.spin_for(FORWARD, 1.3, TURNS)
drivetrain.drive_for(FORWARD, 250, MM)
pusher_motor.spin_for(FORWARD, 10, TURNS)
