How will descoring work this year?
Hello,
Does anyone know about descoring?
If your removing mutliple(above 2) from the stake is it disqualifable or is it not possession. Or like last year type stuff
Don’t want to sound like a broken record but Read the Game Manual it will answer most questions . It is linked below
I’ve fully read it but it isn’t clear within the notion of if removing is the same as in taking and if attempting to pull all of them out as once is disqualifications.
I am pretty sure you can only hold 2 at a time and scored donuts don’t count as in your possession
The rule is that the rings do not count towards possession if they are on a scored on a mobile goal. Using that logic, a robot touching a ring makes it’s score not count. So if you only touch at most 2 rings at a time, it should be fine, except: it would probably break “Spirit of the Rule”.
Ask in the Q&A when it opens tomorrow if you want better clarification! (May 14th)
It looks like removing more than 2 from a stake would be considered possession because you would need to be fully supporting the ring to remove it, unless I’m misunderstanding the rules.
In addition, you need to tilt the ring to remove it off of the rubber top, meaning descoring more than one at a time may not be possible.
Good luck!
Both of these uncertainties posts become rather clear if you read carefully the Game Manual rules and definitions. Please cite specific rules and definitions when building your claims about what is permissible or not. It will greatly improve the quality of your posts.
