I can't get my autonomous work, it just drives straight
For some reason, my auton just drives straight instead of running what it’s coded to do. Here is my code:
#region VEXcode Generated Robot Configuration
from vex import *
import urandom
import math
# Brain should be defined by default
brain=Brain()
# Robot configuration code
left_motor_a = Motor(Ports.PORT18, GearSetting.RATIO_18_1, True)
left_motor_b = Motor(Ports.PORT10, GearSetting.RATIO_18_1, True)
left_drive_smart = MotorGroup(left_motor_a, left_motor_b)
right_motor_a = Motor(Ports.PORT12, GearSetting.RATIO_18_1, False)
right_motor_b = Motor(Ports.PORT1, GearSetting.RATIO_18_1, False)
right_drive_smart = MotorGroup(right_motor_a, right_motor_b)
drivetrain = DriveTrain(left_drive_smart, right_drive_smart, 299.24, 285.75, 254, MM, 0.6)
controller_1 = Controller(PRIMARY)
intake_motor_a = Motor(Ports.PORT20, GearSetting.RATIO_18_1, False)
intake_motor_b = Motor(Ports.PORT11, GearSetting.RATIO_18_1, True)
intake = MotorGroup(intake_motor_a, intake_motor_b)
conveyor = Motor(Ports.PORT19, GearSetting.RATIO_18_1, False)
# wait for rotation sensor to fully initialize
wait(30, MSEC)
# Make random actually random
def initializeRandomSeed():
    wait(100, MSEC)
    random = brain.battery.voltage(MV) + brain.battery.current(CurrentUnits.AMP) * 100 + brain.timer.system_high_res()
    urandom.seed(int(random))
# Set random seed
def play_vexcode_sound(sound_name):
    # Helper to make playing sounds from the V5 in VEXcode easier and
    # keeps the code cleaner by making it clear what is happening.
    print("VEXPlaySound:" + sound_name)
    wait(5, MSEC)
# add a small delay to make sure we don't print in the middle of the REPL header
wait(200, MSEC)
# clear the console to make sure we don't have the REPL in the console
print("\033[2J")
# define variables used for controlling motors based on controller inputs
controller_1_left_shoulder_control_motors_stopped = True
controller_1_right_shoulder_control_motors_stopped = True
drivetrain_l_needs_to_be_stopped_controller_1 = False
drivetrain_r_needs_to_be_stopped_controller_1 = False
#endregion VEXcode Generated Robot Configuration
myVariable = 0
conveyor.set_velocity(50, PERCENT)
intake.set_velocity(180, RPM)
def driver_control():
    while True:
        left_speed = controller_1.axis3.position()
        right_speed = controller_1.axis2.position()
        left_drive_smart.set_velocity(left_speed, PERCENT)
        right_drive_smart.set_velocity(right_speed, PERCENT)
        left_drive_smart.spin(FORWARD)
        right_drive_smart.spin(FORWARD)
        # Intake
        if controller_1.buttonL1.pressing():
            intake.spin(FORWARD)
        elif controller_1.buttonL2.pressing():
            intake.spin(REVERSE)
        else:
            intake.stop()
        # Conveyor
        if controller_1.buttonR1.pressing():
            conveyor.spin(FORWARD)
        elif controller_1.buttonR2.pressing():
            conveyor.spin(REVERSE)
        else:
            conveyor.stop()
    drivetrain.set_drive_velocity(30,PERCENT)
    drivetrain.set_turn_velocity(30,PERCENT)
    wait(20, MSEC)
def autonomous():
    global remote_control_code_enabled
    remote_control_code_enabled = False
    brain.screen.print("RC OFF")
    wait(5,SECONDS)
    drivetrain.drive_for(FORWARD, 6, INCHES)
    # drivetrain.turn_for(RIGHT, 90, DEGREES)
    # drivetrain.drive_for(FORWARD, 64, INCHES)
    # intake.spin(REVERSE)
    # conveyor.spin(FORWARD)
    # wait(3,SECONDS)
    # intake.stop()
    # conveyor.stop()
    # drivetrain.drive_for(REVERSE, 24, INCHES)
    # drivetrain.turn_for(LEFT, 90, DEGREES)
autonomous()
# competition = Competition(autonomous, driver_control)
while True:
    wait(20, MSEC)
If you know what this is or how to fix it, please help :folded_hands:
Looks like that’s all you ask it to do.
It looks like they commented out the rest of the auton code by accident.
You only have the drive forward line active. Every other control line is commented out.
right code:
from vex import *
import urandom
import math
brain=Brain()
wait(30, MSEC)
    wait(100, MSEC)
# Set random seed
    wait(5, MSEC)
wait(200, MSEC)
print("\033[2J")
myVariable = 0
    while True:
        # Intake
        else:
            intake.stop()
        # Conveyor
        else:
            conveyor.stop()
    wait(20, MSEC)
def autonomous():
      wait(3,SECONDS)
      intake.stop()
      conveyor.stop()
autonomous()
while True:
    wait(20, MSEC)
this is python by the way.
Yeah, I accidently sent it with all the comments. Even without them it still just drives straight…
