Implement PID to VEXCode V5
Hello, my teammate who has been working on creating and tuning a pid had just finished his work and now i am wondering how to implement it. Do i have to rewrite the functions from vex or something else? Any help is welcomed!
This is my current non-pid code:
/*    Module:       main.cpp                                                  */
/*    Author:       VEX                                                       */
/*    Created:      Thu Sep 26 2019                                           */
/*    Description:  Competition Template                                      */
// Robot Configuration:
// [Name]               [Type]        [Port(s)]
// Controller1          controller
// Drivetrain           drivetrain    13, 14, 11, 12, 10
// Catapult             motor_group   6, 7
// Intake               motor_group   15, 16
// Pneumatics           digital_out   A
#include "vex.h"
using namespace vex;
competition Competition;
bool intake, Pneu;
// define the drivetrain
// this one is a smart drive which uses the gyro
// gyro and all motors were defined using graphical config
// we have 4 inch wheels
// drive is 16 inches wide between the wheels
// drive has a 16 inch wheelbase (between fron and back wheel axles)
// this is how the above definition would be if no gyro is used
//drivetrain    robotDrive( leftDrive, rightDrive, 12.56, 16, 16, distanceUnits::in );
/*                          Pre-Autonomous Functions                         */
void pre_auton(void) {
  vexcodeInit();
  Pneu = true;
/*                              Autonomous Task                              */
void autonomous(void) {
  // Insert autonomous user code here.
  Drivetrain.setStopping(brake);
  Catapult.setVelocity(100.0, percent);
  Pneumatics.set(false);
  Drivetrain.setDriveVelocity(80.0, percent);
  Drivetrain.setTurnVelocity(40.0, percent);
  Catapult.spinFor(forward, 140.0, degrees);
  Drivetrain.turnToHeading(55.0, degrees);
  wait(0.5, seconds);
  Drivetrain.driveFor(forward, 835.0, mm);
  Drivetrain.turnToHeading(3.0, degrees);
  wait(0.2, seconds);
  Intake.spinFor(forward, 2.0, turns);
  Drivetrain.driveFor(forward, 300.0, mm, false);
  wait(0.5, seconds);
  Drivetrain.driveFor(reverse, 330.0, mm, true);
  // comment
  Drivetrain.turnToHeading(295.0, degrees, true);
  wait(0.2, seconds);
  // comment
  Drivetrain.driveFor(forward, 1075.0, mm, true);
  Drivetrain.turnToHeading(325.0, degrees, true);
  Drivetrain.driveFor(forward, 200.0, mm, true);
  Drivetrain.setTurnVelocity(30.0, percent);
  Drivetrain.turnToHeading(0.0, degrees, true);
  wait(0.1, seconds);
  Drivetrain.driveFor(forward, 400.0, mm, true);
  Drivetrain.turnToHeading(90.0, degrees, true);
  Pneumatics.set(true);
  wait(0.5, seconds);
  Drivetrain.driveFor(forward, 900.0, mm, true);
/*                              User Control Task                            */
void usercontrol(void) {
  while (1) {
    Drivetrain.setDriveVelocity(100.0, percent);
    Drivetrain.setTurnVelocity(100.0, percent);
    Drivetrain.setStopping(coast);
                    // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
  // Set up callbacks for autonomous and driver control periods.
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    //SPIN INTAKE
    //will this work????? the code with bool intake = reverse would constantly tell motors to stop wouldnt they?
    if (Controller1.ButtonR2.pressing()) {
      Intake.spin(forward);
      intake = false;
    } else if (Controller1.ButtonR1.pressing()) {
      Intake.spin(reverse);
      intake = false;
    } else if (!intake) {
      Intake.stop();
      intake = true;
    //Pneumatics toggle
    if (Controller1.ButtonRight.pressing()) {
      if (Pneu) {
        Pneu = false;
        wait(0.1, seconds);
      else {
        Pneu = true;
        wait(0.1, seconds);
    wait(100, msec);
I would ask your teammate, who wrote the code.
In addition to asking your teammate, you could also try and understand it yourself through the George Gillard document . Also, your driver control code should not go inside of the while true loop of main and should instead be inside the while true loop of driver control.
First of all what kind of PID did your teammate make as a pid is just a control function, is it for turning, driving, etc.
