In what ways are we allowed to attack the other robot?
During the drivers meeting at worlds, Grant Cox said something about tombstone’s spinner not being allowed. That was last year so maybe this year it’s allowed. /s
Building on this reply, maybe change attack to interact?
What is a tombstone spinner?
Thanks. I’m new to vex and still trying to learn.
Ignore that. It was sarcastic.
Tombstone is arguably the most destructive combat robot in the world. It has a metal spinning bar that can literally turn a bowling ball into chunks. Obviously, it’s never allowed for that purpose in VRC.
Most destructive battle bot there is.
Tombstone OP plz nerf
Hey so I’ve built a arm that can be used to knock the cubes out of the storage of other robots. I was wondering, is this legal or illegal? Would it be considered offense or just flat out attacking the other bot.
Note: the stack of cubes is NOT the cubes I the scoring zones, they are supposed to be the cubes in the robots tray or whatnot. ( use your imagination)
Official Q&A should be asked for legal or illegal, everything else is pure conjecture.
Causing cubes that are possessed by an opponent robot to no longer be possessed by that robot does not appear to be expressly prohibited by <SG3> (which is the rule that prohibits descoring) or any other rule.
However, in the case of the mechanism in your video (and most mechanisms I can think of to do this), I think <G12> could be a concern. I think it will be very difficult to remove cubes from an opponent robot without entangling them, and you will need to design and use your mechanism very carefully to avoid entangling opponent robots. Even so, the inherent risk of entanglement may be too big to make it worth the risk.
As @lacsap pointed out, the above is just conjecture, and the only way to get an official answer about any rules question is to ask on the Official Q&A.
Yeah I figured that unless you wielded it with surgeon level precision then you’d probably just be bludgeoning everyone with it
This kind of garbage is why my group formed teams under FTC. Instead of spending gobs of time tearing at your opponent, you should spend some time building a bot (and more importantly your skills) that can score.
I can only guess at how little a competitor must think of him/herself to spend more time planning how to interfere the. Planning to score.
This is very true @t243, purposely designing to interfere with the opposing alliance doesn’t attempt to solve the challenge of the Tower Takeover (to efficiently place and score cubes to get more points than the opposing alliance) but I believe it is good to have a robot designed to do both offense and defense depending on who you are with and against and it is good to have the option of using a defensive mechanism if there is a situation that needs it (and of course if you can even afford to add it). However, you probably shouldnt make a mechanism to interfere with the opposing alliance if it cost having a mechanism for scoring/placing or if adding the mechanism for interfering causing your mechanism for scoring/placing to be worse (less power, less room, etc)
the object of the game isn’t to score as many points as you can, its to score more points then the opposing alliance. if you score 1 point and they score none, you’ve met the objective better than if you score 50 and they score 51. if being a defensive robot is how you score more points then your opponents, then that’s how the game is played.
If no defense was allowed, matches would just be four skills runs happening at the same time… What makes them fun to watch is the robot interaction. Yes, maybe it’s “fairer” or “more engineering-focused”… But VEX is a spectator sport. If a carefully controlled, repeatable environment with no outside interaction is your thing, put your effort into the skills challenge instead.
It isn’t a matter of no defense involved. The simple fact is that when you dig into posts and displays Vex has a ton of robots that have near 0 offense ability.
The title of the post reveals a lot of intent. This is beyond some defense and how to ”attack” your opponent.
But with a cursory read of the rules there is a lot of room for strategy which will focus on offensive moves to the detriment of the other team.
I mean, the title is a bit misleading, it’s more about how to interact with other robots, not so much attacking them. If I’m correct, vex rules ban any strategy purely designed to attack and damage other robots
Actually, there is plenty of room for offensive strategy to play into this. For instance, if you are red you could attempt to dominate the greed cubes to the detriment of blue.
There are two towers which could see some fierce interaction on placing a cube. For that matter, one may see a tussle over control of a cube.
Even in autonomous you can’t touch across the line, but the rule stops short of a reach.
There is a lot of room to strategize without moving to attacking another robot. Without trying to knock cubes out. It does appear you can try and knock cubes from the opponents robot. But resorting to that is likely also saying you can’t put think your opponent.
I think this unfair.
having the winning robot/strategy, even if it’s a defensive one, means that you have the smartest strategy. Of course there are rules to keep robots from attacking and destroying each other, and I think it creates a perfect balance between offensive play and defensive play.
if one team builds a super complex mechanism that can score massive points, but loses to a team that has a simple defensive mechanism, like an arm to whack the opponent’s stacks, which team is really more successful? the one that wins, even though their robot was easier to build. defense is just part of the game, it is a completely viable and acceptable strategy, and defensive robots can be superior to offensive robots if they can consistently beat them.
Did we forget to mention that if you’ve ever gone to a vrc match that the field is too small? No matter how you maneuver, robots will always touch, it unavoidable
Edit: nothing against you xenon, you have more experience than me
