Inertial Sensor Autonomous moving weirdly
Hello everyone, we’re a first-year team that recently qualified for states through skills, but our autonomous code is still a major weak point. It’s very inconsistent: the turn values don’t always behave as expected, and sometimes the robot drives strangely (one side moves more than the other, or it turns the wrong way). I’ve pasted our current autonomous code below if anyone could help us diagnose what’s going wrong or point out anything obviously incorrect, it would be a huge help. We’ve been trying to fix this for a long time, but none of our programmers have been able to figure it out yet.
PS: we used python in vexcode v5
#region VEXcode Generated Robot Configuration
from vex import *
import urandom
import math
# Brain should be defined by default
brain=Brain()
# Robot configuration code
# wait for rotation sensor to fully initialize
wait(30, MSEC)
# Make random actually random
def initializeRandomSeed():
    wait(100, MSEC)
    random = brain.battery.voltage(MV) + brain.battery.current(CurrentUnits.AMP) * 100 + brain.timer.system_high_res()
    urandom.seed(int(random))
# Set random seed
def play_vexcode_sound(sound_name):
    # Helper to make playing sounds from the V5 in VEXcode easier and
    # keeps the code cleaner by making it clear what is happening.
    print("VEXPlaySound:" + sound_name)
    wait(5, MSEC)
# add a small delay to make sure we don't print in the middle of the REPL header
wait(200, MSEC)
# clear the console to make sure we don't have the REPL in the console
print("\033[2J")
#endregion VEXcode Generated Robot Configuration
from vex import *
import urandom
import math
brain=Brain()
Right_motor_a = Motor(Ports.PORT1, GearSetting.RATIO_6_1, True)
Right_motor_b = Motor(Ports.PORT2, GearSetting.RATIO_6_1, True)
Right = MotorGroup(Right_motor_a, Right_motor_b)
RightExZ = Motor(Ports.PORT3, GearSetting.RATIO_6_1, True)
Left_motor_a = Motor(Ports.PORT11, GearSetting.RATIO_6_1, False)
Left_motor_b = Motor(Ports.PORT12, GearSetting.RATIO_6_1, False)
Left = MotorGroup(Left_motor_a, Left_motor_b)
LeftExZ = Motor(Ports.PORT13, GearSetting.RATIO_6_1, False)
controller_1 = Controller(PRIMARY)
IMU = Inertial(Ports.PORT10)
Intake_Motor_Top = Motor(Ports.PORT4, GearSetting.RATIO_18_1, False)
Outtake = Motor(Ports.PORT5, GearSetting.RATIO_6_1, False)
digital_out_a = DigitalOut(brain.three_wire_port.a)
digital_out_b = DigitalOut(brain.three_wire_port.b)
wait(30, MSEC)
# Set random seed
wait(200, MSEC)
print("\033[2J")
# Constants
AUTO_VELOCITY = 15  # percent
AUTO_TORQUE = 100   # percent
TRACK_CIRCUMFERENCE = 3.14159 * 9
AUTON_RIGHT_TRIM = 5  # try 5, adjust up/down as needed
# Drive Helper Functions
def LeftDrive_Power(power):
    Left.set_velocity(power, PERCENT)
    LeftExZ.set_velocity(power,PERCENT)
    Left.spin(FORWARD)
    LeftExZ.spin(FORWARD)
def RightDrive_Power(power):
    Right.set_velocity(power, PERCENT)
    RightExZ.set_velocity(power, PERCENT)
    Right.spin(FORWARD)
    RightExZ.spin(FORWARD)
# Autonomous Motor Configuration
def configure_auton_motors():
    Left.set_max_torque(AUTO_TORQUE, PERCENT)
    LeftExZ.set_max_torque(AUTO_TORQUE, PERCENT)
    Right.set_max_torque(AUTO_TORQUE, PERCENT)
    RightExZ.set_max_torque(AUTO_TORQUE, PERCENT)
    Left.set_velocity(AUTO_VELOCITY, PERCENT)
    LeftExZ.set_velocity(AUTO_VELOCITY, PERCENT)
    Right.set_velocity(AUTO_VELOCITY, PERCENT)
    RightExZ.set_velocity(AUTO_VELOCITY, PERCENT)
# Autonomous Movement Functions
def AutonForward(distance_inches: float):
    actual_distance = distance_inches * 2
    degrees_to_spin = (actual_distance / TRACK_CIRCUMFERENCE) * 360
    Left_degrees_to_spin = (degrees_to_spin * 1)
    Left.spin_for(FORWARD, Left_degrees_to_spin, DEGREES, wait=False)
    LeftExZ.spin_for(FORWARD, Left_degrees_to_spin, DEGREES, wait=False)
    Right.spin_for(FORWARD, degrees_to_spin, DEGREES, wait=False)
    RightExZ.spin_for(FORWARD, degrees_to_spin, DEGREES, wait=True)  # Wait for all to finish
def SmoothTurn(target_angle: float, max_speed=50, min_speed=2, kP=0.20, tolerance=2.0):
    Smoothly turns the robot to a specified IMU heading (degrees).
    Slows as it approaches the target to avoid overshooting.
    - target_angle: desired IMU heading (0-360)
    - max_speed: maximum motor percent speed
    - min_speed: minimum speed to avoid stalling
    - kP: proportional gain (tune for your robot)
    - tolerance: how close (degrees) to consider 'done'
    while True:
        current = IMU.heading(DEGREES)
        error = (target_angle - current + 540) % 360 - 180  # shortest path
        if abs(error) <= tolerance:
            Left.stop(BRAKE)
            LeftExZ.stop(BRAKE)
            Right.stop(BRAKE)
            RightExZ.stop(BRAKE)
            break
        # Proportional speed, clamped
        speed = kP * error
        speed = max(-max_speed, min(max_speed, speed))
        # Apply minimum speed to prevent stalling
        if 0 < abs(speed) < min_speed:
            speed = min_speed if speed > 0 else -min_speed
        Left.spin(FORWARD if speed > 0 else REVERSE, abs(speed), PERCENT)
        LeftExZ.spin(FORWARD if speed > 0 else REVERSE, abs(speed), PERCENT)
        Right.spin(REVERSE if speed > 0 else FORWARD, abs(speed), PERCENT)
        RightExZ.spin(REVERSE if speed > 0 else FORWARD, abs(speed), PERCENT)
        wait(10, MSEC)
# Driver Control
def ondriver_drivercontrol_0():
    Left.set_stopping(BRAKE)
    LeftExZ.set_stopping(BRAKE)
    Right.set_stopping(BRAKE)
    RightExZ.set_stopping(BRAKE)
    Intake_Motor_Top.set_velocity(100, PERCENT)
    Outtake.set_velocity(100, PERCENT)
    while True:
        left_power = controller_1.axis2.position()
        right_power = controller_1.axis3.position()
        LeftDrive_Power(left_power)
        RightDrive_Power(right_power)
        if controller_1.buttonB.pressing():
            Intake_Motor_Top.spin(REVERSE)
        elif controller_1.buttonX.pressing():
            Intake_Motor_Top.spin(FORWARD)
        elif controller_1.buttonY.pressing():
            Intake_Motor_Top.stop()
        if controller_1.buttonR1.pressing():
            Outtake.spin(FORWARD)
        elif controller_1.buttonR2.pressing():
            Outtake.spin(REVERSE)
        else:
            Outtake.stop()
        if controller_1.buttonL1.pressing():
            digital_out_a.set(True)
        elif controller_1.buttonL2.pressing():
            digital_out_a.set(False)
        if controller_1.buttonUp.pressing():
            digital_out_b.set(False)
        elif controller_1.buttonDown.pressing():
            digital_out_b.set(True)
        wait(10, MSEC)
# Autonomous Routine
def onauton_autonomous_0():
    # --- IMU Calibration ---
    IMU.calibrate()
    while IMU.is_calibrating():
        wait(20, MSEC)
    Intake_Motor_Top.set_velocity(100,PERCENT)
    Outtake.set_velocity(100,PERCENT)
    AutonForward(34)
    wait(200, MSEC)  # Ensure robot is stopped
    current_heading = IMU.heading(DEGREES)
    SmoothTurn((current_heading + -45) % 360)  # Turn 90 left
    AutonForward(34)
    wait(200, MSEC)
    SmoothTurn((current_heading - 120) % 360)  # Turn 45 right
    AutonForward(45)
    SmoothTurn((current_heading - 37) % 360)  # Turn 45 right
    AutonForward(-30)
# Competition Setup
competition = Competition(ondriver_drivercontrol_0, onauton_autonomous_0)
Edit: we have around 9 days before our next comp and i seem to have fixed it by tweaking the KP values but it still wobbles and wiggles so i would still appreciate the help!
