So we have two drivers. One loves split arcade, the other being an oddball prefers right arcade. Is it possible to code a controller code with split arcade and right arcade while having h drive? I’m using Python btw.
yh
so basically right for H drive + split arcade u can just code standard split arcade but use left side horizontal axis for the holonomic part, or some other axis.
For right arcade H drive just do right arcade but use left axis horizontal for strafing or u can use other combinations ig
To code it, you can use a boolean driver_1 = true. Then, you can do like
driver_1 = True
while True:
if driver_1:
#random driver 1 code
else: #now its driver 2
#random driver 2 code
if button pressed:
driver_1 = False
You could have 2 different programs by just copying the original code onto an new one and change it in the second one and label it different
