Says it all in the title really. I would like to learn how to display a video on the screen without the cable plugged into a computer.
Thank you! ![]()
Thank you! ![]()
You can convert the video into a gif then use this which reads files from the SD card:
It is for pros however. If you are using vexcode, this is a old demo:
you could do it like that or you could manually draw every frame and make it change really fast. but I think it would take longer
I heard that doing it in that method would require more storage for the code than the brain is capable of storing. (Iโm aiming for ~2:30-4:00 minutes of video)
ya for a video that size then the other way is better but if you were to make a small gif or something you could use this method
I wish you the best of luck, especially if using GIFs for this.
The best alternative here (which may handle 2:30 of efficient, ugly codec video footage) would be using a small and light GZip library to decompress in-memory, since the V5 brain has more memory/RAM capacity than immediate flash storage (see GitHub - mapbox/gzip-hpp: Gzip header-only C++ library ยท GitHub ). Please also look into libsimplewebm for WebM headers, since WebM handles compression reasonably quickly and saves storage space relatively well.
