this is a part of my code that says there is 6 errors in it can you help
int main() {
vexcodeInit();
// Define motors
motor motorgroup3 = motor(PORT3, ratio18_1, true);
motorgroup3.spin(Forward, slowspeed, velocityUnits::pct)
motorgroup3.stop()
Make sure that you add semicolons after every command that you give, and that you are giving valid parameters, with the correct format of:
Motor.spinFor(directionType, rotation, units);
or
Motor.spin(directionType, voltage, volt);
For example:
MotorGroup3.spinFor(forward, 90, degrees);
or
MotorGroup3.spin(forward, 3.0, volt);
