Issues with motor_group
I used the code above and used the names in the code. However, the following errors still appeared:
Here’s my code. Can anyone tell me what’s wrong? Thanks in advance!
Robot Configuration
#include "vex.h"
using namespace vex;
using signature = vision::signature;
using code = vision::code;
// A global instance of brain used for printing to the V5 Brain screen
brain Brain;
// VEXcode device constructors
motor LeftTop = motor(PORT10, ratio18_1, true);
motor RightTop = motor(PORT20, ratio18_1, false);
motor LeftBottom = motor(PORT6, ratio18_1, true);
motor RightBottom = motor(PORT16, ratio18_1, false);
motor Motor19 = motor(PORT19, ratio36_1, false);
motor Motor9 = motor(PORT9, ratio36_1, true);
motor Snapper = motor(PORT11, ratio18_1, false);
motor_group LeftSide = motor_group(LeftTop, LeftBottom);
motor_group RightSide = motor_group(RightTop, RightBottom);
motor_group Lift = motor_group(Motor9, Motor19);
controller Controller1 = controller(primary);
// VEXcode generated functions
* Used to initialize code/tasks/devices added using tools in VEXcode Text.
* This should be called at the start of your int main function.
void vexcodeInit( void ) {
// nothing to initialize
Actual Driver Control Code
/*    Module:       main.cpp                                                  */
/*    Author:       VEX                                                       */
/*    Created:      Thu Sep 26 2019                                           */
/*    Description:  Competition Template                                      */
// Robot Configuration:
// [Name]               [Type]        [Port(s)]
// LeftTop              motor         10
// RightTop             motor         20
// LeftBottom           motor         6
// RightBottom          motor         16
// Motor19              motor         19
// Motor9               motor         9
// Snapper              motor         11
// Controller1          controller
#include "vex.h"
competition Competition;
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the V5 has been powered on and        */
/*  not every time that the robot is disabled.                               */
void pre_auton(void) {
  vexcodeInit();
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
void autonomous(void) {
  // Insert autonomous user code here.
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
void usercontrol(void) {
  while (1) {
    // This is the main execution loop for the user control program.
    // Each time through the loop your program should update motor + servo
    // values based on feedback from the joysticks.
    // Insert user code here. This is where you use the joystick values to
    // update your motors, etc.
Lift.setVelocity(50, percent);
Snapper.setVelocity(100, percent);
int leftMotorSpeed = Controller1.Axis3.position();
    // Get the velocity percentage of the right motor. (Axis2)
    int rightMotorSpeed = Controller1.Axis2.position();
    // Set the speed of the left motor. If the value is less than the deadband,
    // set it to zero.
    if (abs(leftMotorSpeed) < 10) {
      // Set the speed to zero.
      LeftSide.setVelocity(0, percent);
    } else {
      // Set the speed to leftMotorSpeed
      LeftSide.setVelocity(leftMotorSpeed, percent);
    // Set the speed of the right motor. If the value is less than the deadband,
    // set it to zero.
    if (abs(rightMotorSpeed) < 10) {
      RightSide.setVelocity(0, percent);
    } else {
      // Set the speed to rightMotorSpeed
      RightSide.setVelocity(rightMotorSpeed, percent);
    // Spin both motors in the forward direction.
    LeftSide.spin(forward);
    RightSide.spin(forward);
    if(Controller1.ButtonL1.pressing()) {
      Lift.spin(forward);
    else if (Controller1.ButtonL2.pressing()) {
      Lift.spin(reverse);
    else {
      Lift.stop(hold);
    if(Controller1.ButtonR1.pressing()) {
      Snapper.spin(forward);
    else if (Controller1.ButtonR2.pressing()) {
      Snapper.spin(reverse);
    else {
      Snapper.stop(hold);
                    // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
  // Set up callbacks for autonomous and driver control periods.
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
did you add declarations into robot-config.h or vex.h ?
No, I didn’t. How can I do it? @jpearman
well, have a look at what’s there and do the something similar for motor groups. something like this. You can add to vex.h or robot-config.h
extern motor_group LeftSide;
