Issues with Robot Mesh C++
I have recently ran into a problem with Robot Mesh. I am trying to make a toggle system for an intake which is not working. The toggle if facilitated by the variable “b”. Does anyone have any suggestions?
Here is my program:
   // VEX V5 C++ Project with Competition Template
    #include "vex.h"
    using namespace vex;
    //#region config_globals
    vex::brain      Brain;
    vex::motor      motorL(vex::PORT12, vex::gearSetting::ratio18_1, false);
    vex::motor      motorS(vex::PORT9, vex::gearSetting::ratio18_1, false);
    vex::motor      motorR(vex::PORT10, vex::gearSetting::ratio18_1, true);
    vex::motor      motorUD(vex::PORT3, vex::gearSetting::ratio18_1, true);
    vex::motor      motorUD2(vex::PORT4, vex::gearSetting::ratio18_1, true);
    vex::motor      motorI(vex::PORT6, vex::gearSetting::ratio18_1, true);
    vex::motor      motorCUD(vex::PORT7, vex::gearSetting::ratio18_1, true);
    vex::controller Controller1(vex::controllerType::primary);
    int b = 0;
    //#endregion config_globals
    // Creates a competition object that allows access to Competition methods.
    vex::competition Competition;
    void pre_auton() {
    // All activities that occur before competition start
    void autonomous() {
    // Autonomus
     Brain.Screen.setFillColor(color::green);
     Brain.Screen.render();
    void drivercontrol() {
    // Driver Control
    while (true) {
         //Drive
       motorL.spin(vex::directionType::fwd,  Controller1.Axis2.value()/1.4 + Controller1.Axis4.value()/2, vex::velocityUnits::pct);
       motorR.spin(vex::directionType::fwd, Controller1.Axis2.value()/1.4 + Controller1.Axis4.value()/2 * -1, vex::velocityUnits::pct);
        //Move ramp up and down
      if (Controller1.ButtonR1.pressing()) {
         motorUD.spin(vex::directionType::fwd, 255, vex::velocityUnits::pct);
         motorUD2.spin(vex::directionType::fwd, 255, vex::velocityUnits::pct);
     else if (Controller1.ButtonR2.pressing()) {
         motorUD.spin(vex::directionType::rev, 255, vex::velocityUnits::pct);
         motorUD2.spin(vex::directionType::rev, 255, vex::velocityUnits::pct);
     else if (not Controller1.ButtonR2.pressing() or not Controller1.ButtonR1.pressing()) {
         motorUD.spin(vex::directionType::fwd, 0, vex::velocityUnits::pct);
         motorUD2.spin(vex::directionType::fwd, 0, vex::velocityUnits::pct);
        //Intake motor toggle
        if (Controller1.ButtonUp.pressing()) {
            if (b = 0) {
                b = 1;
            else if (b = 1) {
                b = 0;
     else if (Controller1.ButtonDown.pressing()) {
            if (b = 0) {
                b = -1;
            else if (b = -1) {
                b = 0;
     //Intake Move
     if (b = 1) {
         motorI.spin(vex::directionType::fwd, 255, vex::velocityUnits::pct);
     else if (b = -1) {
         motorI.spin(vex::directionType::rev, 255, vex::velocityUnits::pct);
     else if (b = 0) {
         motorI.spin(vex::directionType::fwd, 0, vex::velocityUnits::pct);
        //Move claw up and down
     if (Controller1.ButtonL1.pressing()) {
     else if (Controller1.ButtonL2.pressing()) {
     else if (not Controller1.ButtonL2.pressing() or not Controller1.ButtonL1.pressing()) {
         //Strafe
      if (Controller1.Axis1.value() > -25 or Controller1.Axis1.value() < 25) {
       motorS.spin(vex::directionType::fwd, Controller1.Axis1.value(), vex::velocityUnits::pct);
            //Screen drawing
        Brain.Screen.clearLine(1, color::blue);
        Brain.Screen.clearLine(2,color::red);
        Brain.Screen.clearLine(3,color::blue);
        Brain.Screen.clearLine(4,color::blue);
        Brain.Screen.clearLine(5,color::red);
        Brain.Screen.clearLine(6,color::red);
        Brain.Screen.clearLine(7,color::blue);
        Brain.Screen.clearLine(8,color::blue);
        Brain.Screen.clearLine(9,color::red);
        Brain.Screen.clearLine(10,color::red);
        Brain.Screen.clearLine(11,color::blue);
        Brain.Screen.clearLine(12,color::blue);
        Brain.Screen.setCursor(0,1);
        Brain.Screen.print(b);
        Brain.Screen.render(); //Prevent flickering, b/c it is annoying and weird looking.
    int main() {
    // Do not adjust the lines below
    // Set up (but don't start) callbacks for autonomous and driver control periods.
    Competition.drivercontrol(drivercontrol);
    // Run the pre-autonomous function.
    pre_auton();
    // Robot Mesh Studio runtime continues to run until all threads and
    // competition callbacks are finished.
@John_TYler?
This will give you a clue.
Thank You! I forgot the difference.
