GDC has just ruled you can use plastic from VEXIQ Bankshot game. By extension, the ruling makes it clear if the plastic meets the robot rules regarding plastics it is ok to use.
I might totally scavenge some flag lexan. I knew it was legal because it was the same thickness, but, not having any lexan (I know, shame on me!), that flag pecan could be spectacular. I just have to be careful not to use too much.
This will be very helpful for teams who want to recoup their investment (or help the environment) by reusing previous seasons’ field elements, as well as those who just want something more unique on their robot.
I assume teams would still need to take precautions to prevent the flag plastic from interfering with the vision sensor, though, in case the sensors confuse the red and blue plastic with the colored tiles and protected zone barriers, or confuse the green plastic with the green cubes (although there’s only a small amount of green plastic).
(I suppose the white V might be confused with the white lines on the field, but this may be less likely.)
If I had one here i’d try the solvents in my shop. I’m certain an orbital sander would make fast work of the paint if you are willing to have opaque plastic.
