Mechanic question
We are having problems with the chassis. Although there is no problem with the engines and wheels, the chassis is warped. There is no problem with the code. One side rotates less than the other side but as I said the motors are the same and there is no problem We cleaned the gaps between the wheels, but the power transfer still seems uneven. How can we solve this problem?
Have you tried with different motors and made sure the wire is properly connected? Also, is where the bearing attached bent slightly? Those could be the cause of your problem
Check your wires for any parts exposed or just not plugged in enough. You also mentioned the chassis is warped meaning that you could have bent a shaft which could make the amount of power going in lower.
There doesn’t seem to be any problem with our shafts. Also our autonomous works well. I mean whien we start the autonom section, our chassis go ahead with no deviation in direction. I’m going to share our chassis with you to understand the problem properly. Fusion
We have a little problem with having motors. We will install the engines crosswise and see if the same problem occurs.
Can we have a picture of your chasis? preferably one of the top, the front, and the bottom.
