My dr4b not lifting
My dr4b is not lifting. We added rubber band and still it wont move an inch.
Try adding more rubber bands? There should be a lot of banding on it. Can you lift it by hand or is it just the motor that can’t lift it?
The rubber bands are only on the bottom, so your lift isn’t getting the advantage it needs to lift. It could also be friction if you can’t move it by hand.
I’m not a v5 builderbut maybe it’s a coding error. Make sure you motor group is not pushing against echother
The dr4b isn’t moving with a motor group. This means that the problem is mechanical. Though, once you do build it well enough to consistently lift up and down, this is something you want to check for.
it’s just that the motor can’t lift it.
Can u explain it furthur? What is a motor group.
Do you have 2 motors or one motor? A motor group is when you group 2 motors in the code so that when you press a button on the remote both spin at the same time. It’s basically just how to code using 2 motors on one lift.
A motor group is exactly what it sounds like. In code, you can pair motors together with the same name triggered by the same event. When pairing motors, there is an option for one to rotate one way and the other rotates opposite, which is what you want. This likely isn’t the problem at the moment, because if it were, you’d see a lot of twisting or mechanical stress/clicking. If you can move it without the motor, it is likely just that it doesn’t get the necessary advantage to lift, so you can either minimize the friction, (or if you’ve already done so) or you can add more rubber bands. Do note that some arrangements of rubber bands can actually counteract the motor and force it downwards.
Are the motors spinning the metal directly? It should be geared down 12:84 with your current setup.
