Need help with drivetrain gearing and gear positioning
I am trying to create a cad of my robot for this year. I am planning to do a 6m 55w drive at 450 rpm or something close. I am using 3 wide c-channels because I want to save space when mounting motors side by side. I don’t know how to mount the gear so that they will mesh. I want to use the smallest gears possible. How should I do this?
First off, why are you using 3 wide? I know you said it saves space but at the cost of you having a heavier drivetrain, and motors overheating quicker. Also wouldn’t a 66 watt 450 rpm be better than a 55 watt due to the 5.5 watt motors having more friction. Also what wheel size are you planning to use?
I agree with you saying it should be 450 on 66 watts because you have to do special gearing to get the 5.5 to have the same speed/tourqe of the regular 11 watt motors
I think that 3 wide is completely viable. yes fine there may be a weight of a fly that is added, but if you are building vertical motors or have some weird gear ratio, it is fine.
I was planning to use 3 wide because I want vertical motors. It saves space while still giving my code an easy way to work due to how I have programmed it. I should use 66w rather then 55w but i would have more motors to work with doing 55w. I’m doing double ltc intakes. I feel that it would be better then one because you can have 12 blocks rather then 6. How should I do a 36 to 48 or something close? Because of the weird gear positioning I might have to drill holes but I would really prefer not to.
I’d say to try and offset your gears in a diagonal way to make room to make sure they all connect
That is unfortunately hard to do because I am using 3 wide. 3 wide doesn’t have the row offset like the 2 wide has. I just need a gear ratio that gets close to 450 rpm and I think i’m going to do 6m rather then 5m.
Catalogue of Drive Gearings
This should be useful
Thanks, but I have already used that
If you’re doing 55w, since the 5.5w motor only spins at 200rpm (no cartridges), if you want the gears to be as small as possible, you must do a compound gearing.
I have already decided to not use 5.5s on the drive and only do it for the intake. That lets me have 6 11w for the drive and 4 5.5w for the intake. I have already settled on a design and I’m almost done cadding the drive. Just have to finish copying the right side to the left and then brace it and connect the sides
Can we see photos or something, would love to see your solution
