New Products - May 2022 (EXP Products for V5)
VEX seems to be shifting away from all of the low strength options, and leaning more into the high strength accessories. Gears, wheels, and more are receiving the “low strength” → “high strength” makeover. It’s unlikely that these gear sizes will receive low strength options.
VEX released high strength gears after they released the low strength gears, then made a V2 of the said high strength gears, not revamping the low strength gears at all. This, as well as all of the following product changes recently, have led me to believe that VEX is encouraging everything high strength. Following this theme, it seems unlikely that VEX will release low strength gears of the 24, 48, and 72 gears.
Is this going to have increased friction on low strength shafts compared to the plastic high strength round adapters?
This new one is made of metal, the old ones were made of plastic.
With the metal on metal action, would this new product be susceptible to grinding and increased friction?
You might have noticed that the round bore is nor only round, but also different color. I.e. different metal. That’s a very important detail. The round bore could be made of brass, but most likely it’s made of “bearing bronze”, a special composition metal used, well, for bearings. You most likely have a few bronze bearings in the PC you’re reading this message on, they are often used in computer fans. And about everywhere, when you need a bearing, but can’t really go all the way with ball bearing.
BTW: It would be great if VEX stated that on the product page. We’re educating future engineers and we want them to know why, not only how.
I might assume it’s just a matter of time before the material is added, since it is listed for older components.
Yep, good call.
For future reference,
  • The square bore (276-8235) is SMF 5040 Steel.
  • The round bore (276-8034) is Sintered Bronze.
I’ll add this information to the product page.
May I ask why Bronze? Like what advantages does it give?
Bronze, an alloy of copper and tin, is a common bearing material because it is hard, strong, and wear resistant. When making a sleeve bearing, which is a “sliding bearing” rather than a “roller bearing”, it is important that the bearing material be slightly softer than the shaft material, so that the wear will be in the bearing rather than the shaft. Bronze has an additional property that it doesn’t gall (or stick) to the steel, which would pull of microscopic bits of material during wear. Rather, it wears away very slowly (especially if lubricated a bit), while offering a low coefficient of friction against the steel shaft.
(To learn more, you can take Materials 101 class at Monroe County Community College :slight_smile: )
Besides that, it is sintered bronze, which means it is slightly porous. You can infuse the pores with lubricant for even better properties.
and as an added bonus, you can tell if it is a square bore or round bore by just looking at the color, like the square/round high strength shaft inserts
Bearings were always able to fit inside the flange of a C-Channel, they just couldn’t fit on the web side.
This is a bearing in the flange of cut 3 wide.
I noticed that some of these are 6x12 and 6x6 instead of multiples of 5 like the other plates. Is this similar to how exp metal is in 4 hole sections?
Powdered metal, heated to just before melting into a smooth mixture. Contains pores/holes for lubricant.
