New to PID help
we are trying PID for the first time and we followed a youtube tutorial by Connor 1814D and our robot will not move for whatever reason, any help or sources would be very useful
here is the code:
Module: main.cpp /
Author: VEX /
Created: Thu Sep 26 2019 /
Description: Competition Template /
#include “vex.h”
using namespace vex;
vex::motor BLeftMotor = vex::motor( vex::PORT8,true );
vex::motor FLeftMotor = vex::motor( vex::PORT16,true );
vex::motor BRightMotor = vex::motor( vex::PORT2,true );
vex::motor FRightMotor = vex::motor( vex::PORT11,true );
vex::motor IntakeR = vex::motor( vex::PORT20,true );
vex::motor IntakeL = vex::motor( vex::PORT17,true );
vex::motor TopBoi = vex::motor( vex::PORT19,true );
vex::motor BallCarry = vex::motor( vex::PORT12,true );
vex::motor Scorer = vex::motor( vex::PORT4,true );
//vex::limit ClickyBoi =vex::limit( Brain.ThreeWirePort.A);
vex::controller Controller = vex::controller();
competition Competition;
/* Pre-Autonomous Functions /
You may want to perform some actions before the competition starts. /
Do them in the following function. You must return from this function /
or the autonomous and usercontrol tasks will not be started. This /
function is only called once after the V5 has been powered on and /
not every time that the robot is disabled. /
void pre_auton(void) {
vexcodeInit();
// Example: clearing encoders, setting servo positions, …
//PID
//Constants
double kP = 0.00001;
double kI = 0;
double kD = 0;
double TurnkP = 0;
double TurnkI = 0;
double TurnkD = 0;
//AutonStoof
int desiredValue = 300;
int desiredTurnValue = 0;
int error; //SensorValue - DesireValue : Position
int prevError = 0; //Position 20 milliseconds ago
int derivative; //error - prevError : Speed
int totalError = 0; //totalError = totalError + error
int Turnerror; //SensorValue - DesireValue : Position
int TurnprevError = 0; //Position 20 milliseconds ago
int Turnderivative; //error - prevError : Speed
int TurntotalError = 0; //totalError = totalError + error
bool resetDriveSensors = false;
//Varibles
int drivePID(){
if (resetDriveSensors) {
resetDriveSensors = true;
BLeftMotor.setPosition(0, degrees);
BRightMotor.setPosition(0, degrees);
FLeftMotor.setPosition(0, degrees);
FRightMotor.setPosition(0, degrees);
//Get the position of both motors
int BleftMotorPosition = BLeftMotor.position(degrees);
int BrightMotorPosition = BRightMotor.position(degrees);
int FleftMotorPosition = FLeftMotor.position(degrees);
int FrightMotorPosition = FRightMotor.position(degrees);
// Lateral movement PID
//average of 4 motors
int averagePostion = (BleftMotorPosition + BrightMotorPosition + FleftMotorPosition + FrightMotorPosition );
//Potential
error = averagePostion - desiredValue;
//Derivative
derivative = error - prevError;
//Intengral
totalError += error;
double LateralMotorPower = (error * kP + derivative * kD + totalError * kI);
double TurnMotorPower = (Turnerror * TurnkP + Turnderivative * TurnkD + TurntotalError * TurnkI);
BLeftMotor.spin(forward, LateralMotorPower + TurnMotorPower, voltageUnits::volt);
BRightMotor.spin(forward, LateralMotorPower - TurnMotorPower, voltageUnits::volt);
FLeftMotor.spin(forward, LateralMotorPower + TurnMotorPower, voltageUnits::volt);
FRightMotor.spin(forward, LateralMotorPower - TurnMotorPower, voltageUnits::volt);
// Turning movement PID
int TurnaveragePostion = (BleftMotorPosition + BrightMotorPosition + FleftMotorPosition + FrightMotorPosition );
//Potential
Turnerror = TurnaveragePostion - desiredTurnValue;
//Derivative
Turnderivative = Turnerror - TurnprevError;
//Intengral
TurntotalError += Turnerror;
//code
prevError = error;
TurnprevError = Turnerror;
vex::task::sleep(1);
return 1;
Autonomous Task /
This task is used to control your robot during the autonomous phase of /
a VEX Competition. /
You must modify the code to add your own robot specific commands here. /
void autonomous(void) {
vex::task Drive(drivePID);
desiredValue = 300;
desiredTurnValue = 600;
vex::task::sleep(3);
desiredValue = 300;
desiredTurnValue = 300;
User Control Task /
This task is used to control your robot during the user control phase of /
void usercontrol(void) {
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
                // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
I believe you need a while loop around your PID so it is constantly updating.
we put it in a while loop and it still does nothing.
Here is the code:
Module: main.cpp /
Author: VEX /
#include “vex.h”
vexcodeInit();
//PID
//Constants
double kI = 0;
double kD = 0;
double TurnkP = 0;
double TurnkI = 0;
double TurnkD = 0;
//AutonStoof
int desiredTurnValue = 300;
//Varibles
bool enableDrivePID = true;
int drivePID(){
while(enableDrivePID){
int BleftMotorPosition = BLeftMotor.position(vex::degrees);
int BrightMotorPosition = BRightMotor.position(vex::degrees);
int FleftMotorPosition = FLeftMotor.position(vex::degrees);
int FrightMotorPosition = FRightMotor.position(vex::degrees);
//Potential
//Derivative
//Intengral
//Potential
//Derivative
//Intengral
//code
prevError = error;
return 1;
Autonomous Task /
desiredValue = 300;
desiredValue = 300;
User Control Task /
while (1) {
int main() {
pre_auton();
while (true) {
wait(100, msec);
You can format your code by putting it in [code] ... [/code] brackets. Like so:
/  Module: main.cpp  <em>/
/  Author: VEX  <em>/
/  Created: Thu Sep 26 2019  <em>/
/  Description: Competition Template  <em>/
#include “vex.h”
/  You may want to perform some actions before the competition starts.  /
/  Do them in the following function. You must return from this function  /
/  or the autonomous and usercontrol tasks will not be started. This  /
/  function is only called once after the V5 has been powered on and  /
/  not every time that the robot is disabled.                                         /
vexcodeInit();
//PID
//Constants
double kI = 0;
double kD = 0;
double TurnkP = 0;
double TurnkI = 0;
double TurnkD = 0;
//AutonStoof
//Varibles
int drivePID(){
//Potential
//Derivative
//Intengral
//Potential
//Derivative
//Intengral
//code
prevError = error;
return 1;
/  Autonomous Task  <em>/
/  This task is used to control your robot during the autonomous phase of  /
/  a VEX Competition.  /
/  You must modify the code to add your own robot specific commands here.  /
desiredValue = 300;
desiredValue = 300;
/  User Control Task  /
/  This task is used to control your robot during the user control phase of /
/  You must modify the code to add your own robot specific commands here./
while (1) {
int main() {
pre_auton();
while (true) {
wait(100, msec);
I see two problems (with more possible problems, but let’s start with these). Firstly, you create a task called Drive in the first code you posted, but not in the second one. Whassup with that? You need to make a task with the function, so definitely do that.
Secondly, your kP is VERY small. It may work for you, but you may want to try making it larger if you have problems with the robot not moving.
To add on to this, often times the reason PID loops don’t work is out-of-bounds constants. Try messing around with them a little.
You may need to increase your kP value as the values you are getting are two low to overcome the friction of existing. As a starting point use 0.01 as a kP value and either raise or lower it depending on whats happening.
Also, you may need to include vex::task taskName(drivePID); into your code for it to work.
Hope this helps
this code is frightfully long. is it just a drive function?
No it’s a PID loop
20 char
Another think I noticed was you arent taking the average of the 4 motor values, you forgot to add / 4 to the end of the line like this.
+ FleftMotorPosition + FrightMotorPosition ) / 4;
It helps to learn PID incrementally, these resources are well worth reading. Copying code is alright until you need to fix it
