I have been trying to rewrite a bunch of code I lost unsuccessfully. The function I use to tell the robot to rotate doesn’t work and I can remember what I did last year to make it work. I remember passing a certain variable to it making the robot rotate the correct amount of degrees. The goal of the code is to make the robot face a target it sees on the vision sensor by turning towards it, and then calculating the distance to target and moving. Any info on solving this issue with turning is appreciated. Thanks!.
/* Module: main.cpp */
/* Author: C:\Users\REDACTED */
/* Created: Fri Sep 23 2022 */
/* Description: V5 project */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Drivetrain drivetrain 2, 1, 11
// Vision10 vision 10
// Arm motor 4
// Hand motor 5
// Expander9 triport 9
// RangeFinder9A sonar A, B
// GPS20 gps 20
// Controller1 controller
#include "vex.h"
using namespace vex;
event checkRed = event();
event checkMagenta = event();
event checkGreen = event();
event checkDistance = event();
void detection(){
wait(1, seconds);
double travel = RangeFinder9A.distance(inches);
double move = travel - 20;
Drivetrain.driveFor(forward, move, inches);
void visionLocation() {
printf("CenterX: ");
printf("%.2f", (double)Vision10.largestObject.centerX);
printf("\n");
printf("CenterY: ");
printf("%.2f", (double)Vision10.largestObject.centerY);
printf("\n");
void targetObject() {
//JPearman Example
int TARGET = 150;
int error = Vision10.largestObject.centerY - TARGET; //How far off center is the item.
// simple P control with a limit of 50
int drive = error;
if( drive > 50 ) drive = 50;
if( drive < -50 ) drive = -50;
// object is found and centered
if( Vision10.largestObject.centerY > (TARGET-15) && Vision10.largestObject.centerY < (TARGET+15) ) {
Drivetrain.stop();
//Move forward based on distance from target, account for length of robot.
else {
Drivetrain.turnToRotation(degrees, drive); //What does drive do?
detection();
void hasMagentaCallback() { //Add target object somewhere when ready
Brain.Screen.setFont(mono40);
Brain.Screen.clearLine(1, black);
Brain.Screen.setCursor(Brain.Screen.row(), 1);
Brain.Screen.setCursor(1, 1);
Controller1.Screen.clearScreen();
Controller1.Screen.setCursor(1,1);
Vision10.takeSnapshot(Vision10__SIG_1);
if (Vision10.objectCount > 0) {
Brain.Screen.print("Magenta Object Found");
Controller1.Screen.print("Magenta Object Found");
} else {
Brain.Screen.print("No Magenta Object");
Controller1.Screen.print("No Magenta Object");
int main() {
vexcodeInit();
Drivetrain.setDriveVelocity(25, percent);
targetObject();
//checkMagenta(hasMagentaCallback);
while (true) {
checkMagenta.broadcastAndWait();
wait(1, seconds);
