Took home Tourney Champ, Skills and the innovate award. Feel free to ask any questions!
did you run into any issues in terms of defense with an extended arm? Are you using four omni wheels? :48 in your video you hit a flag with two balls, why does the flag not get fully toggled? What were some of your team’s struggles? What do you feel went well with yourself, and then your team as a whole?
1:21 It’s a wild Bread
Also, you guys should work on your descoring because it seems like it consistently knocks caps out of the field. Remember that a repetition of that could lead to a disqualification
@NightsRosario Yea we paired with 1533M to take the dub. We have also started to hook the caps around the pole and pull it in.
@meepmeepme
Did you run into any issues in terms of defense with an extended arm? So far we haven’t it works well for descoring and for flipping ground caps.
Are you using four omni wheels? Yup, 4 omnis not locked on 1:1 200rpm v5
:48 in your video you hit a flag with two balls, why does the flag not get fully toggled? It shot two balls and the first one toggled it then the second one hit the flag again and caused it to bounce back, it counted as toggled in the end though.
What were some of your team’s struggles? Well, the main one was that we got v5 the day before the event and decided it would be beneficial to switch, we rebuilt and got a solid auton by then and in the end, it was worth it.
What do you feel went well with yourself, and then your team as a whole? I feel like my driving was the best it had ever been at this comp (thanks impart to my co-driver) My whole team couldn’t be there but going as a two-person team worked well, our flywheel gear stripped out and we were able to fix it between two matches. Im also super proud of everyone else getting the bot ready in such short notice.
