OnShape Field Simplified
I’ve remodeled the Override Field CAD on Onshape.
It includes:
  • textures for all elements
  • connector mates on pins goals and cups
  • parametric and simplified pins, rollers, goals
  • field tape as either faces or a separate part
  • slideable match loader
  • match, skills and empty field layout (the one in the image is wrong and has been fixed)
(Onshape)
Inspired by Giovanni_7282R from the previous seasons,
Thanks so much! You’re an absolute legend. I’ve been procrastinating doing this myself for a good while now you just saved me so much time.
Wow, thanks for sharing this great resource!
For future reference to everyone using this cad, though, I found that the match loaders are not actually slidable, but in fact fixed. After looking at the mates connecting the loader pieces together, the problem appears to be that the pin slot 1 mate’s limit was distanced incorrectly (shown below).
The match loader has 3 options for heights. The first two are fixed and third is movable. This was done for mainly performance reasons.
Oh, ok. Tysm for explaining!
Hi I am new to vex v5 and have just started cading my first robot and was wondering what this field file would be used for. I am guessing that it might be to import your robots cad to test the dimensions but if that’s true, how would you cad your robots so you could move the individual part of the robot, such as the lift?
