Override 55W Drive Train Ideas
With the new season VRC 26/27 Override there is a new drive train motor limit of 55W. Whats the best way to optimize the drive train and not to overheat the motor by using 44W 600rpm. Can you guys share what your teams are working on?
Thanks in Advance.
Just think of your own solutions. The season has been active for like a bit more than two weeks. See what ratios work and dont and then ask for feedback
@lacsap Already said it perfectly in another post:
Are you planning on using 44w 600 rpm? This won’t work at all, no matter how you optimize it.
450 rpm 2.75 with 55 watts works quite well. I encourage you to tinker with slower drive configs compared to other years considering the loss of 11 watts. That being said, the mentioned ratio is plenty fast.
44W 600rpm will definitely overheat. the teams tried before and motors begin to overheat after 2 matches.
thanks Lucas, i think its the gear arrangement that is challenging as its requires compound gear trains. thats the part that i feel its hard to teach the junior teams on
my team plans on doing a 450 rpm, 44W x-drive. That would give you a similar max speed to a 600 rpm direct drive
Hey, do you know if there is some kind of math that I can do to figure out if my motors are going to overheat with my drivetrain? I want to see if I can determine that before I make my chassis, if at all possible.
I would recommend that you stop looking at RPM and switch to IPS (inches per second - or cm per second). The field is 144 inches across so it makes it very easy to understand how quickly your robot can move within the area.
Here are some recommended speeds for chassis. Note that friction and weight will affect your results.
  • Recommended / safe range for most teams: about 50–62 IPS
  • Fast but still reasonable: about 62–70 IPS
  • Above 70 IPS: only for teams that really know what they’re doing
Example:
  • Motor = 200 RPM
  • Drive gear = 60 tooth
  • Driven gear = 36 tooth
  • Wheel = 3.25 inches
Gear ratio is 60 ÷ 36 = 1.67
200 RPM / 60 = 3.33 RPS (rev per second)
3.33 [RPS] × 1.67 [ratio] × 3.25 [wheel] × 3.141 [PI] = 56.86 IPS
I totally agree with your statement.
What do you guys think about this drivetrain?: a 257 RPM on 4’’ omnis with 200 RPM greens and a 36:28 ratio. I feel like this might be fast while keeping enough torque for the end of the match.
Weird but linear ips isn’t that bad. To my knowledge they only make 24t gears not 28 and the 24t are metal which would increase weight. I would stick to a more traditional ratio but on the surface this idea isn’t terrible.
This also increases friction
Sorry for adding onto this thread, but do y’all think a 55 watt 400rpm drivetrain with 3.25" wheels is okay for this season? If not, what would be a reasonable rpm for a 55 watt 3.25" wheel drivetrain?
I think ours is 55 watt, 360 rpm and 3’25 wheels. Also, how many wheels do you have? We have 8 wheels and these numbers should work, so if you have 6-8 wheels it should work.
Yeah, the design I cadded uses 6 wheels (4 omni 2 traction).
