I’ve been wanting to use a PD loop for our team’s drivetrain during auton. Before adding the Derivative, the P loop was off. When we tested a negative value it would cause the bot to move forward about 2-4 feet, then move back 2-4 feet. How can it be changed to move in a single direction?
The code:
void resetDriveSensors (){
leftBack.setPosition(0, degrees);
rightBack.setPosition(0, degrees);
leftFront.setPosition(0, degrees);
rightFront.setPosition(0, degrees);
void lateralMovement(double targetValue){
// Gets the position of the motor in degrees
int leftMotorPosition = leftFront.position(degrees);
int rightMotorPosition = rightFront.position(degrees);
int leftBackMotorPosition = leftBack.position(degrees);
int rightBackMotorPosition = rightBack.position(degrees);
// Divides the positions to get the average
int averagePosition = (leftMotorPosition + rightMotorPosition + leftBackMotorPosition + rightBackMotorPosition)/4;
double error = targetValue - averagePosition;
double Kp = 0.5;
double lMotorSpeed;
while (fabs(error)>4){
lMotorSpeed = Kp*error;
rightFront.spin(forward, lMotorSpeed, pct);
leftFront.spin(forward, lMotorSpeed, pct);
leftBack.spin(forward, lMotorSpeed, pct);
rightBack.spin(forward, lMotorSpeed, pct);
leftFront.stop(brake);
leftBack.stop(brake);
rightBack.stop(brake);
rightFront.stop(brake);
We are using the motor encoders because all of the tri-ports are used and we don’t have an extender. This while, while (fabs(error)>4)
, is so that there is some wiggle room so it have to get the error all the way to zero.
