PID driving too far then reversing
Hi,
I recently wrote a pid code. An issue I am encountering is that it will consistently drive to far and then reverse when the integral value increases. Here is a look at the code that makes the robot drive forward, turn around, and then drive back. Thanks for the help.
#include "vex.h"
using namespace vex;
motor leftFront = motor(PORT1, ratio18_1,false);
motor leftBack = motor(PORT11, ratio18_1,false);
motor rightFront = motor(PORT10, ratio18_1,true);
motor rightBack = motor(PORT20, ratio18_1,true);
int desiredValue = 0;
int Kp = 100;
int Ki = 10000;
int Kd = 100;
int totalError = 0;
int prevError = 0;
bool enableYPID = false;
bool enableTurnPID = false;
int main() {
  vexcodeInit();
  leftFront.setStopping(hold); //tell the drivebase to not let the wheels spin unless told too.
    rightFront.setStopping(hold);
    leftBack.setStopping(hold);
    rightBack.setStopping(hold);
  enableYPID = true;
  int desiredValue = 1800;
  while(enableYPID) {
  int averagePosition = (leftFront.position(degrees) + leftBack.position(degrees ) + rightFront.position(degrees) + rightBack.position(degrees ))/2;
  int error = averagePosition - desiredValue;
  totalError += error;
  int diffrenceError = error - prevError;
  int Speed = error / Kp + totalError / Ki + diffrenceError / Kd;
  leftFront.spin(reverse, Speed, voltageUnits::volt);
  rightFront.spin(reverse, Speed, voltageUnits::volt);
  leftBack.spin(reverse, Speed, voltageUnits::volt);
  rightBack.spin(reverse, Speed, voltageUnits::volt);
  prevError = error;
  wait(0.02, sec);
  if( error < 3 and error > -3 ){
    enableYPID = false;
  enableYPID = false;
  leftFront.spin(reverse, 0, voltageUnits::volt);
  rightFront.spin(reverse, 0, voltageUnits::volt);
  leftBack.spin(reverse, 0, voltageUnits::volt);
  rightBack.spin(reverse, 0, voltageUnits::volt);
  Brain.Screen.print("stuff");
  wait(1, sec);
 enableTurnPID = true;
  int desiredTurnValue = 1800;
  while(enableTurnPID) {
  int averagePosition = (leftFront.position(degrees) + leftBack.position(degrees ) - rightFront.position(degrees) - rightBack.position(degrees ))/2;
  int error = averagePosition - desiredTurnValue;
  rightFront.spin(forward, Speed, voltageUnits::volt);
  rightBack.spin(forward, Speed, voltageUnits::volt);
  prevError = error;
  wait(0.02, sec);
  Brain.Screen.print("  more  stuff");
  wait(1, sec);
  enableYPID = true;
   desiredValue = 3600;
  while(enableYPID) {
  prevError = error;
  wait(0.02, sec);
    enableYPID = false;
  enableYPID = false;
  Brain.Screen.print("  even  more stuff");
this might help.
Sounds like you just haven’t tuned it enough.
This is a great resource for PID. You can check out the tuning section to see how to better tune your constants.
@9MotorGang
I recently put together a collection of resources that provide more insight into PID. They range from a beginner to advanced level so it should be easy to follow through no matter your skill level. Additionally, there are both theoretical and concrete examples provided. I highly recommend reading through each resource as each one has unique strengths. You can find it here.
What you are currently experiencing is known as overshoot. The materials I provided should help you understand why this happens and how you can fix this.
