Pneumatics whistle
A random thought that could be fun a pneumatics whistle. When ever the solenoid switches sates air needs to be released it seems like a fun idea to hook up all of the releases holes to a whistle. This would just be completely decorative so you could 3d print this.
Kinda a random fun idea.
Any you guys have fun ways to use the release air from pneumatics.
With sufficient solenoids and t fittings, you could totally make an entire scale of notes and play songs. Then this would be the equivalent of a high pitched V5 compatible speaker. I find this a very cool idea, if anyone is capable of doing this I will be very impressed.
On a competition bot this would be fun for about 5 minutes.
@Sylvie
20 characters
Hi yes that’s me can I help you?
Do it, make a horn. (Gdhshwvwbzbh)
​​​​n​​​o​​​​​​​​​​​​​​​​​​​​​​​​​​​.
I know I’m not taran but I’ll try to do it sometime (probably after my states is over as I’m going to be working non stop until then). It sounds like a fun idea.
Challenge accepted, I’ll post the results here once/if I get it to work (it’ll be a while because I have other priorities for things I must get done before states but I will also try and do this before then as well).
That looks great! Have they tried adding some form of flow regulator or pressure regulator to change which note is played or how long it is played for? Otherwise super cool test, hopefully this is a step forwards towards my dream of someone playing never going to give you up with 100 PSI some day.
