I am wondering how to gear my DR4B. I am using standoffs to push the bottom of the lift up. Currently i have two red cartridge motors spinning 12 tooth gears that get geared down to 48 tooth gears. The banding is good because the lift stays wherever i put it. Since the lift is quite slow i was wondering if I could use green motors instead. With the same gearing. The big question is would it have enough power to power it?
Sounds like you are using standoff linkage dr4b.
Here’s the original for your reference - https://youtu.be/xbqURp5oiAc?is=yupIPoS5kfsErQXE
