Programming/Controller
When we run our program, the controller to drive only works on one joystick, even though it is programmed to run on both. I have uninstalled and reinstalled the program but it still does not work. Any suggestions?
Could you possibly show us your code? I wouldn’t be able to figure out the problem (if you would mind, of course.)
We are having the same issue- when using the remote the controls keep changing even though the code has not changed.
Maybe you should check if the motor and cable are working (by trying a different motor). You should also check what it is bound to on the program, it should be so that there are arrows on both buttons. I hope this fixes your problem!
It would be very helpful if you send screenshots of your code so we could see if anything is wrong there
Otherwise just call Vex Support
