#pragma region VEXcode Generated Robot Configuration
// Make sure all required headers are included.
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <math.h>
#include <string.h>
#include "vex.h"
using namespace vex;
competition Competition = competition();
// Brain should be defined by default
brain Brain;
// START V5 MACROS
#define waitUntil(condition) \
do { \
wait(5, msec); \
} while (!(condition))
#define repeat(iterations) \
for (int iterator = 0; iterator < iterations; iterator++)
// END V5 MACROS
// Robot configuration code.
motor leftMotorA = motor(PORT8, ratio18_1, false);
motor leftMotorB = motor(PORT9, ratio18_1, false);
motor_group LeftDriveSmart = motor_group(leftMotorA, leftMotorB);
motor rightMotorA = motor(PORT5, ratio18_1, true);
motor rightMotorB = motor(PORT6, ratio18_1, true);
motor_group RightDriveSmart = motor_group(rightMotorA, rightMotorB);
drivetrain Drivetrain = drivetrain(LeftDriveSmart, RightDriveSmart, 319.19, 295, 40, mm, 1);
inertial Inertial13 = inertial(PORT13);
motor Motor3 = motor(PORT3, ratio18_1, false);
controller Controller1 = controller(primary);
motor Motor2 = motor(PORT2, ratio18_1, false);
// generating and setting random seed
void initializeRandomSeed(){
int systemTime = Brain.Timer.systemHighResolution();
double batteryCurrent = Brain.Battery.current();
double batteryVoltage = Brain.Battery.voltage(voltageUnits::mV);
// Combine these values into a single integer
int seed = int(batteryVoltage + batteryCurrent * 100) + systemTime;
// Set the seed
srand(seed);
void vexcodeInit() {
//Initializing random seed.
initializeRandomSeed();
// Helper to make playing sounds from the V5 in VEXcode easier and
// keeps the code cleaner by making it clear what is happening.
void playVexcodeSound(const char *soundName) {
printf("VEXPlaySound:%s\n", soundName);
wait(5, msec);
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
// define variables used for controlling motors based on controller inputs
bool Controller1RightShoulderControlMotorsStopped = true;
bool DrivetrainNeedsToBeStopped_Controller1 = true;
// define a task that will handle monitoring inputs from Controller1
int rc_auto_loop_function_Controller1() {
// process the controller input every 20 milliseconds
// update the motors based on the input values
while(true) {
if(RemoteControlCodeEnabled) {
// calculate the drivetrain motor velocities from the controller joystick axies
// left = Axis2 + Axis1
// right = Axis2 - Axis1
int drivetrainLeftSideSpeed = Controller1.Axis2.position() + Controller1.Axis1.position();
int drivetrainRightSideSpeed = Controller1.Axis2.position() - Controller1.Axis1.position();
// check if the values are inside of the deadband range
if (abs(drivetrainLeftSideSpeed) < 5 && abs(drivetrainRightSideSpeed) < 5) {
// check if the motors have already been stopped
if (DrivetrainNeedsToBeStopped_Controller1) {
// stop the drive motors
LeftDriveSmart.stop();
RightDriveSmart.stop();
// tell the code that the motors have been stopped
DrivetrainNeedsToBeStopped_Controller1 = false;
} else {
// reset the toggle so that the deadband code knows to stop the motors next time the input is in the deadband range
// only tell the left drive motor to spin if the values are not in the deadband range
LeftDriveSmart.setVelocity(drivetrainLeftSideSpeed, percent);
LeftDriveSmart.spin(forward);
// only tell the right drive motor to spin if the values are not in the deadband range
RightDriveSmart.setVelocity(drivetrainRightSideSpeed, percent);
RightDriveSmart.spin(forward);
// check the ButtonR1/ButtonR2 status to control Motor3
if (Controller1.ButtonR1.pressing()) {
Motor3.spin(forward);
Controller1RightShoulderControlMotorsStopped = false;
} else if (Controller1.ButtonR2.pressing()) {
Motor3.spin(reverse);
} else if (!Controller1RightShoulderControlMotorsStopped) {
Motor3.stop();
// set the toggle so that we don't constantly tell the motor to stop when the buttons are released
// wait before repeating the process
wait(20, msec);
return 0;
task rc_auto_loop_task_Controller1(rc_auto_loop_function_Controller1);
#pragma endregion VEXcode Generated Robot Configuration
/* Module: main.cpp */
/* Author: {author} */
/* Created: {date} */
/* Description: V5 project */
struct Action {
enum Type { // type of our instruction
WAIT, // in miliseconds
FORWARD, // in meters
TURN, // in degrees
REVERSE, //in meters
SETROTATION,
Type type;
float value;
Action(Type t, float v) { type = t; value = v;} // constructor
void turn_robot(float rotation) {
float actualRotation = Inertial13.rotation(degrees);
float targetRotation = rotation;
float error = targetRotation - actualRotation;
float motorSpeed = 0.0;
float threshold = 2.0; // Stop when error is within 2 degrees
float kP = 0.5; // Proportional gain (adjust as needed for your robot)
float minSpeed = 8;
// Loop until we reach the target heading
while (fabs(error) > threshold) {
if (fabs(error) < threshold) {
RightDriveSmart.stop(brake);
LeftDriveSmart.stop(brake);
break;
motorSpeed = kP * error; // Proportional speed (positive for right, negative for left)
// Cap speed to prevent excessive turning (adjust min/max as needed)
if (motorSpeed > 60.0) motorSpeed = 60.0;
if (motorSpeed < -60.0) motorSpeed = -60.0;
if (fabs(motorSpeed) < minSpeed)
motorSpeed = (motorSpeed > 0 ? minSpeed : -minSpeed);
// Set direction and speed
if (motorSpeed > 0) {
// Turn right
RightDriveSmart.setVelocity(motorSpeed, pct);
LeftDriveSmart.setVelocity(motorSpeed, pct);
LeftDriveSmart.spin(reverse);
} else if (motorSpeed < 0) {
// Turn left
RightDriveSmart.spin(reverse);
} else {
// Stop if error is zero (though threshold should handle this
break;
// Small wait for sensor update and control loop
wait(20, msec);
void execute_autonomous_instruction(Action instruction) { // we process all the actions here
switch (instruction.type) {
case Action::WAIT :
wait(instruction.value, msec);
break;
case Action::FORWARD:
Drivetrain.setDriveVelocity(75, percent);
Drivetrain.driveFor(forward, instruction.value, mm);
Drivetrain.stop();
break;
case Action::TURN:
turn_robot(instruction.value);
Drivetrain.stop();
break;
case Action::REVERSE:
Drivetrain.driveFor(reverse, instruction.value, mm);
Drivetrain.stop();
break;
case Action::SETROTATION:
Inertial13.setRotation(instruction.value, degrees);
break;
void autonomous(void) {
// Reset sensors if needed
RemoteControlCodeEnabled = false;
Inertial13.setRotation(0, degrees);
Action autonomous_actions[] = {
Action(Action::TURN, 90.f),
Action(Action::WAIT, 50),
Action(Action::SETROTATION, 0),
Action(Action::TURN, -90.f),
for(Action action : autonomous_actions) {
execute_autonomous_instruction(action);
void usercontrol(void) {
// Enable the remote control task
while (1) {
// Keep this loop open so the background task continues to run
wait(20, msec);
int main() {
vexcodeInit();
// Begin project code
Inertial13.calibrate();
while (Inertial13.isCalibrating()) {
wait(2000, msec);
// Stop the drivetrain once target is reached
Drivetrain.stop();
return 0;
I have been trying to program inertial sensor for weeks. This is my recent code. I have tried ai’s and they also add many things. But still it just makes our robot spin to the right for one time, stop nearly a second and turn endlessly. We don’t think there is an issue with the position of inertial. Do you have any suggestions?
