Does anyone know how to transfer my code from my laptop in PROS to the brain?
The first thing you need to do is build the project. You can do this by opening the PROS integrated terminal and running the command pros make
. If it compiles successfully, you can then upload the project with the command pros upload
plug one end of the USB cable into your laptop.
plug the other end into the V5 brain.
pros upload
https://pros.cs.purdue.edu/v5/tutorials/walkthrough/uploading.html
