Can someone explain these errors? I’m new to PROS and I have no idea why this isn’t working
It would help if we knew what the errors actually were. I think hovering over the red dot by the error should tell you what that specific error is, or click in the red dot in the bottom left corner should tell you all the errors.
- ‘main.h’ file not found
- use of undeclared identifier ‘pros’
This is a very common error which I have seen occur when PROS is installed and opened for the first time. I forget exactly how I resolved this issue, but take a look at this forum thread which has an explanation of the issue and some suggestions to resolve the issue.
