PROS Program installation failing
I was trying to install some programs using PROS cli, and or some reason it was able to download and run, but it doesn’t seem to run any of my code, including controller rumble, serial print, lcd print, controller print, and direct program exiting, and the whole time it still doesn’t respond to what i use at all
Pros version:
> pros --version
pros, version 3.8.0
Brain info:
> pros v5 status
Connected to V5 on /dev/ttyACM0
System version: 1.1.5-0
CPU0 F/W version: 1.1.0-6
CPU1 SDK version: 1.1.5-0
System ID: 0x4cdba500
System Info:
> neofetch        0
                   '                      c@e
                  'o'                     ---
                 'ooo'                    OS: Artix Linux x86_64
                'ooxoo'                   Host: LENOVO 20BTS4DS00
               'ooxxxoo'                  Kernel: 7.1.9-artix1-2
              'oookkxxoo'                 Uptime: 2 hours, 41 mins
             'oiioxkkxxoo'                Packages: 1815 (pacman), 12 (flatpak)
            ':;:iiiioxxxoo'               Shell: zsh 5.9.2
               `'.;::ioxxoo'              Resolution: 1920x1080
          '-.      `':;jiooo'             DE: Plasma 6.7.4 (XLibre)
         'oooio-..     `'i:io'            WM: KWin
        'ooooxxxxoio:,.   `'-;'           Theme: Breeze-Dark [GTK2], Breeze [GTK3]
       'ooooxxxxxkkxoooIi:-.  `'          Icons: breeze-dark [GTK2/3]
      'ooooxxxxxkkkkxoiiiiiji'            Terminal: tmux
     'ooooxxxxxkxxoiiii:'`     .i'        CPU: Intel i5-5300U (4) @ 2.900GHz
    'ooooxxxxxoi:::'`       .;ioxo'       GPU: Intel Broadwell-U GT2 [HD Graphics 5500]
   'ooooxooi::'`         .:iiixkxxo'      Memory: 4071MiB / 7807MiB
  'ooooi:'`                `'';ioxxo'
 'i:'`                          '':io'
pros upload also gives no errors, it just says it’s done, and the program when installed says made with pros just doesn’t do anything at runtime
