Python No such attribute Error
I encountered some issues while coding, where the line
self.mtrgrp_L = vex.MotorGroup(self.mtr_LF, self.mtr_LM, self.mtr_LB)
self.mtrgrp_R = vex.MotorGroup(self.mtr_RF, self.mtr_RM, self.mtr_RB)
always throws an error: “No such attribute.” I’m not sure why this is happening
code:
# Robot Configuration
# This class contains all the configuration for the robot, including motors, sensors, and other components.
# Do not change the configuration unless you know what you are doing.
class RobotConfig:
    # Chassis Parameters
    wheel_diameter_in = 3.25
    gear_ratio = 60 / 36
    # Brain
    brain = vex.Brain()
    # Motors
    mtr_LF = vex.Motor(vex.Ports.PORT1, vex.GearSetting.RATIO_18_1, False)
    mtr_LM = vex.Motor(vex.Ports.PORT2, vex.GearSetting.RATIO_18_1, False)
    mtr_LB = vex.Motor(vex.Ports.PORT3, vex.GearSetting.RATIO_18_1, False)
    mtr_RF = vex.Motor(vex.Ports.PORT4, vex.GearSetting.RATIO_18_1, False)
    mtr_RM = vex.Motor(vex.Ports.PORT5, vex.GearSetting.RATIO_18_1, False)
    mtr_RB = vex.Motor(vex.Ports.PORT6, vex.GearSetting.RATIO_18_1, False)
    # IMU
    imu = vex.Inertial(vex.Ports.PORT21)
    # Pneumatics
    pneumatics = vex.Pneumatics(brain.three_wire_port.a)
    # Encoders
    enc_x = vex.Rotation(vex.Ports.PORT7, True)
    enc_y = vex.Rotation(vex.Ports.PORT8, True)
    # Vision Sensor
    vision = vex.AiVision(vex.Ports.PORT11)
    # Control Parameters
    brake_type = StandardBrakeTypes.COAST
# Robot Class
# This class is the instantiation of robot configuration.
# It contains all the components of the robot.
# Do not change the code in this class. If you want to change the configuration, change the `RobotConfig` class.
class Robot():
    def __init__(self):
        self.wheel_diameter_in = RobotConfig.wheel_diameter_in
        self.wheel_diameter_mm = self.wheel_diameter_in * 25.4
        self.wheel_circum_mm = self.wheel_diameter_mm * math.pi
        self.gear_ratio = RobotConfig.gear_ratio
        # Brain
        self.brain = RobotConfig.brain
        # Motors
        self.mtr_LF = RobotConfig.mtr_LF
        self.mtr_LM = RobotConfig.mtr_LM
        self.mtr_LB = RobotConfig.mtr_LB
        self.mtr_RF = RobotConfig.mtr_RF
        self.mtr_RM = RobotConfig.mtr_RM
        self.mtr_RB = RobotConfig.mtr_RB
        # Motor Groups
        # IMU
        self.imu = RobotConfig.imu
        # Pneumatics
        self.pneumatics = RobotConfig.pneumatics
        # Encoders
        self.enc_x = RobotConfig.enc_x
        self.enc_y = RobotConfig.enc_y
        # Vision Sensor
        self.vision = RobotConfig.vision
        self.brake_type = RobotConfig.brake_type
robot = Robot()
IIRC, MotorGroup is not part of the vex module so using “vex.” preceding it won’t work.
Removing the ‘vex.’ should fix it.
thanks! i think the problem is solved
