Question abt AK toggles/ side toggles chain guard
Hi guys
I was wondering how I could protect the chain for my toggle with poly
do u guys have any idea what to do?
A lot of teams just double chain their toggle which I would probably recommend instead of wasting plastic on it. Just make sure your chain is mostly inside the robot and double chained and you should be good. Also use 6p chain because it’s generally stronger.
Each piece of poly you get can only be 4x8. I wouldn’t recommend wasting poly on it, but I would say that you should keep the chain closer to the inside of the robot. If you really want to shield it that bad, then don’t waste poly, cause it is helpful for other things and also hard to connect sometimes, just use aluminum sheets or c-channel. using c-channel that covering it with an aluminum sheet would work pretty well.
