RAMSETE Controller oscillating
I made a full RAMSETE controller algorithm to pull data from path.jerryio.com files in python using vscode for my robot, my program works in a straight line but when it turns/runs a curves path it just oscillates back and forth. any ideas on how to fix this issue?
i have tried adding a margin for error and adjusting my b and zeta values for tuning, i also have tried capping the speed of the motors and it still doesn’t work. The google doc linked below has my program in it.
GoogleDocs
were you ever able to fix this issue? i had the same issue
@henry_bag I remember you mentioning that path.jerryio.com does not provide the info needed for a RAMSETE controller.
in path.jerry io it lets you access to “min/max” speed/rpm, and throughout the path you can adjust the rpm, however this only includes linear velocity, you have to calculate angular velocity on your own
