Unfourtunatley I don’t have any pictures, however if you look at the ace 229V Gatr1 reveal you will see how this designs casacde lift works.
I was thinking of it to be used as a anti tip , however i’m probably going to switch the design to low strength axels on the drive to be used as one instead.
pls keep sending updates and what is going to spin your front intake i done see a motot or any thing
Are you looking to holecount? Just don’t
There is a motor in a picture above.
You might try worm gears on the cascade? might help prevent gear slipping. Also you could consider using a passive and save a piston.
I have a passive in the fromt, however i am considering modifying the back one to also be passive.
Sorry, I mean a passive claw for the pins and cups. I haven’t seen one so far, and I’m a bit confused as to why teams wouldn’t try one. I’m cadding one myself and it seems to going pretty well.
